First time at the track...decent times
Well, I just got back from englishtown from the first time runnin my car.
Scanner isnt working so ill scan soon but here's all the numbers.
First time they only clocked 1/8mile
R/T - .532
60' - 1.988
330' - 5.531
1/8 - 8.385
mph - 87.16
Second run they were doing 1/4
R/T - .377
60' - 1.895
330' - 5.365
1/8 - 8.204
mph - 86.52
1000 - 10.658
1/4 - 12.690
mph - 112.02
Last run wasnt ready but still did decent.
R/T - .555
60' - 1.841
330' - 5.312
1/8 - 8.158
mph - 86.63
1000 - 10.601
1/4 - 12.627
mph - 112.35
All runs were done on Stock Clutch/ Stock 2-step.
Mods are: 05' tbe,mbc,intake,280s,walbro,flash
R/T - .532
60' - 1.988
330' - 5.531
1/8 - 8.385
mph - 87.16
R/T - .377
60' - 1.895
330' - 5.365
1/8 - 8.204
mph - 86.52
1000 - 10.658
1/4 - 12.690
mph - 112.02
R/T - .555
60' - 1.841
330' - 5.312
1/8 - 8.158
mph - 86.63
1000 - 10.601
1/4 - 12.627
mph - 112.35
not bad times, but you will improve with practice. the first thing holding you back is your 60', then it looks like the 1-2 shift judging by your 330' times.
You said you have a flash but your still using the stock 2 step... tell your tuner to up the stationaty rev limit to 5800-6000. that should help your 60'. then just work on more practice and you'll be running low 12s high 11s in no time, as long as you don't smoke your stock clutch trying, lol.
Ya, im getting rid of my whole set up this winter and clutch, i just wanted to get a ball park of where I was at before I changed everything. I got tuned last march and havent really messed with anything. I may try and get out one more time before they close. But thanks
Decent times overall. Could use some improvement on the 60ft. Also faster shifting too. With your mods you should be in the low 12's depending on altitude and temp and humidity.
I ran a 7.7 in the 1/8 with a 1.7 60ft @ 90mph with only a mbc, mail in, drop in, 3in tbe, and 02.
Oh by the way I have your 1/8th on vid if you want to check it out
