My new best time
Old Nov 4, 2006 | 03:22 PM
hova00's Avatar
My new best time
Evo IX with a custom flash, Bushur turboback, k&n drop in, smc meth. 100%, dtec boost cont., and aps dv.
60' - 1.819(i know it is not good but the car would not hook up)
330- 4-988
1/8- 7.659 @ 92.79
1000- 9.943
1/4- 11.875@116.86
What do you guys think of this run. With a mid 1.6 60' time i def.
will be good for mid 11's. Boost was spiking to about 25lbs and only holding 21 by redline. I was trying to get a 30lb spike and hold 22-23 by redline but that wasnt happening. Any suggestions on better boost control or driving are appreciated.
Old Nov 4, 2006 | 03:26 PM
1NastyEvo's Avatar
Nice!
Have you dyno'd the car ?
Also 100% meth meaning no gas ? 91 or 93 mixture?
Old Nov 4, 2006 | 03:31 PM
hova00's Avatar
Car dynoed last week with some tweeks made to the tune numbers were 433 ft lbs and 402 whp on a dynojet. Tuning was done by Sean Ivey. Yes the car runs on 93 octane with 100% meth from my smc kit. meaning it is not diluted with water like some people do for various reasons.
Old Nov 4, 2006 | 03:34 PM
1NastyEvo's Avatar
I see.
God damn man, your car is frickin nuts.
Love it
Old Nov 4, 2006 | 04:00 PM
hova00's Avatar
Thanks
Old Nov 4, 2006 | 05:18 PM
AlwaysinBoost's Avatar
thats a great time espically for the few mods. how were you coming out whole, did you spin or bog?
Old Nov 4, 2006 | 05:25 PM
4Gsixty3's Avatar
very impressive time! Sean Ivey is the man!
Old Nov 4, 2006 | 05:28 PM
hova00's Avatar
I was using the 2 step which is set at 6300 rpms. Car spun bad and the back end kicked out to the right hard off the line.
Old Nov 4, 2006 | 11:26 PM
Warrtalon's Avatar
Impressive other than the fact you trapped ~116 on a base flash and straight pump gas, or at least that's what you told us.
Old Nov 5, 2006 | 02:35 AM
freshevo8's Avatar
he's using smc meth. 100%. other than that, very impressive for your mods. your car would hit and 11.7 with a better '60ft for sure. what was your tire pressure set at? or could've been because it was the cooler season of the year.
Old Nov 5, 2006 | 02:53 AM
Ang Wen Yan's Avatar
Nice for 1.8 60'!!
Old Nov 5, 2006 | 06:02 AM
94AWDcoupe's Avatar
Very nice time for mods. Try a high boost acuator. Forge or FP.
Old Nov 5, 2006 | 06:18 AM
Warrtalon's Avatar
Yes, I know, but when he was the first IX to hit 11s, he was trapping 115-116 and said it was with just stg1 mods, 93oct, and a base flash from TurboTrix (no meth). No one could figure out how he could possibly trap that high on a base flash with pump gas. Now, he trapped 116 again but with a custom tune, meth, and running as much boost as he can. That's what I was referring to...
Old Nov 5, 2006 | 06:42 AM
3000ways's Avatar
+1
Impressive time and trap speed, but I thought your previous best was 11.9@115mph with out meth. But the reason for not seeing great gains, could possibly be due to the fact that your not running much more boost. I would think that with the meth kit you could turn the boost up to atleast 28psi on pump gas. When your car made 402whp/433wtq, what boost was that at?
Old Nov 5, 2006 | 07:40 AM
hova00's Avatar
Those numbers came from spiking 30lbs and tapering down toward redline, but i cant get the boost to go that high at the track all it will to is spike 25 and come down to 21-22 towards redline. The forge actuator will help for sure. I ran the 11.9 @ 115 on straight pump and also posted the video to prove it because there were alot of haters that still dont believe it. With a mid 1.6 60' time i would have def. run 11.6 at least if i can get the boost up to were it should be i would trap a few mph higher. Any suggestion on the dtec boost controller settings that i should be using.
