made it to track after 5 years
well I finally made it to a track for some drag passes after 5 years...forgot how much fun it could be.
Car, 03 evo w/ sx dp, greddy evo 2 cat back (no cat). sx dual stage mbc @ 21 psi, vishnu flash done on dyno, clutch (unk was in car when bought)
Track: elevation was roughly 4200ft, section of road corse so a slight up hill to it.. trees and staging beams were used. Yes the section was 1/4 mile..track is HUGE the straight is almost 3/4 mile long.
Most of the runs I had a problem getting into 4th..My best et./trap was 13.3 @ 102 with 2 attempts at getting it into 4th gear. I need to work on that..might be time to rebuild the tranny going into 5th with any rpm above 3k I get a grind...and 4th was a bi#ch getting into on most of my runs. So I know there is a high 12 in the set up with some better shifting..
Nice times. I'm assuming in Fernley? With our elevation, you should be able to squeeze in 1 or 2 more psi of boost. Once you work out your tranny issues, it looks like you have a 12 sec car at 4200'.
yup It be Ferntucky..car pulls pretty good @ 21 psi..I won't go over that until I replace the factory boost gage. don't much like the idea of having more boost than can be indicated.
cerevo
Jun 13, 2020 11:15 AM
evodave
For Sale - Cars For Sale
14
Jan 5, 2007 09:55 AM
