***Why am I so slow? Times Inside***
Old Aug 7, 2007 | 07:47 AM
  #31
matt55's Avatar
Originally Posted by LIL EVOL
It also seems that there may be a little bit of air leaking from my stock DV.
What ?
Old Aug 7, 2007 | 08:07 AM
  #32
LIL EVOL's Avatar
I had the DV and snorkel disconnected when I did the test and ran the tester to the turbo inlet. Today at idle it seemed as though the DV had air coming from it...not the connection either...hell at this point who knows.
Old Aug 7, 2007 | 09:01 AM
  #33
Warrtalon's Avatar
- The stock DV opens at idle like it should
- You can't detect a boost leak at idle anyway
- The DV should have been on during the test
- The snorkel is the piece that sends air to the stock airbox. The MAF pipe is the hose that sends air from the intake to the turbo.
Old Aug 7, 2007 | 09:06 AM
  #34
LIL EVOL's Avatar
Do I not remove the snorkel and connect the boost leak tester? thus leaving it hanging? I know newbie type questions just making sure I understand...do I pull the maf and filter and run the boost leaker tester through the snorkel?
Old Oct 18, 2007 | 08:39 PM
  #35
phantomblack04's Avatar
500hp GTO and only hitting 12.5 on drag radials that doesnt sound right.
Old Oct 19, 2007 | 04:39 AM
  #36
LIL EVOL's Avatar
traction for sure...but its true....its all good in the twelves now before my 50-trim...better results in the coming weeks.
Old Oct 19, 2007 | 05:14 AM
  #37
Evoryder's Avatar
GOOD video...
something devilish is going on with your car. I am pretty impressed that you found 'zero' leaks...good job i guess? Does your car feel real strong? 13.2 is amazing...I knocked out a 13.1 untuned in my VIII with just a 3" buschur TBE
Make sure you're boost leak testing properly...
Old Oct 19, 2007 | 05:22 AM
  #38
EVOB23's Avatar
Originally Posted by Evoryder
GOOD video...
LOL. Okay more about the tune? It was a self tune. mail in flash, or what. It says you got a 50 trim not a nine turbo. More specifications. I think I might be lost.
Old Oct 19, 2007 | 07:33 AM
  #39
TouringBubble's Avatar
Here is a simple question ... did you log the run? Heat soak could be triggering some knock. That would help explain the slow second half.
If you didn't log the run, take the car out and do a few 2nd or 3rd gear pulls back to back and see if anything happens.
Now, if knock caused those runs, then you were likely seeing a bit of knock ... I'd estimate 6+ for enough time to drop the octane flag a bit ...
Good luck on a solution.
BTW, I've had luck shifting at about 6600 - 6800, but I'm on the 10.5 and a 6-speed. I'm honestly not too fast either ...
Old Oct 19, 2007 | 08:07 AM
  #40
evovin's Avatar
what video?
GOOD video...
Old Oct 19, 2007 | 09:06 AM
  #41
SickSilverNLow's Avatar
wow....thats kinda slow man. Get tuned and check again for boost leaks and then go to the track. PM me if you need anything bro.
Old Oct 22, 2007 | 09:49 PM
  #42
MrJdmJimi's Avatar
go to a different track and see what you do .....you said the gto seem fast but had a bad time ..maybe the problem is the track.........
Old Oct 22, 2007 | 10:17 PM
  #43
BGevoIX's Avatar
There are a lot of little things you have to do to correctly perform a boost leak test. It's not just a matter of hooking up the tester and pumping air through it. And like the other guy said...the snorkel is the piece that's connected to the lid of the stock air box. You do disconnect your intake tube off the turbo. I believe you also have to plug the vacuum port going to the diverter valve and plug the line coming out of the valve cover that goes back into the intake tube...I think that's about it. If there is more to it...someone else chime in. I also see that he has a 50 trim kit in his sig for mods...so unless he has that already tuned and running good, this would be good for anyone to know in case there are issues later on.
Old Oct 26, 2007 | 11:22 AM
  #44
rcjustin's Avatar
ya idk why but uyour def down on power or bad shift points because ur trap is nowhere near where it should be.
Old Oct 26, 2007 | 11:38 AM
  #45
LIL EVOL's Avatar
Let this thread die...old news....look at the post date. I've since ran in the 12s before my 50-trim and ACT Clutch install...NEXT UP 11s.
MyEvoRocksUrv8
Aug 9, 2008 07:34 PM
hellcat
Mar 19, 2007 06:10 PM
SRT-TO-EVO
Oct 18, 2006 11:29 AM
vwjeff
Jun 28, 2006 01:44 PM
EV0-VIII
Aug 19, 2005 08:47 PM
