slow 50trim
slow 50trim
I STILL havent fixed the boost leaks but I went to the track anyways. Got there late around 8pm, closed around 9 due to rain. First run was 12.1 @ 121!
2nd
60'-1.77
1/8- 7.8
1/4- 12.02 !!!!!! F@CK
MPH-...............122.96!!!!!
3RD
60'- 1.79
1/4- 12.09 I gotta get this boost leak fixed!!!
MPH-122.XX.....
I'm shifting like crap and have several boost leaks now, track was cool and I was pulling really decent. Man I wish I had a boost controller and some race gas, I can only imagine. I really need to get my butt in gear and get outta the hole in the 1.6's. Im dropping out of boost during shifts, but I'm way to afraid to no lift to shift. Im SUCH a wuss! Any comments welcome, I know that my shifting is slow, and my 60's aren't that great but other than that fire away. Thanks Matt W.
2nd
60'-1.77
1/8- 7.8
3RD
60'- 1.79
MPH-122.XX.....
You have a 50 trim and no boost controller? If you are having boost leaks, get them fixed before you go to the track. Get a boost leak tester or just take it to a shop, its not going to be that expensive to fix.
You are getting pretty good mph so with some more aggresive driving on your current "leaky" set-up you should be able to run mid 11's.
I just havent had time to build one yet. I really dont prefer shops for anything other than to use a dyno (and we don't have any around where I live). Ive just had way to many things going on to take the time to test it and it was a last minute decision to drive to the track so late. I think the problem is down low, Im just not pulling good until half way down the track. I know with proper driving (fast shifting) it could go 11s...I just dont have it in me yet to shift it that hard. I have ran soooo many 12.0 at 120. Im mainly just excited about the 122.96 mph on pump gas and full weight (3500 with me in it) Thanks for the comment. Matt W.
Fix that boost leak asap. Thats a great trap, but I know there is alot fater ET left on the table. Mod your ECU with EcuFlash with the NLTS patch to help eliminate dropping out of boost. Here is a thread showing you how:
https://www.evolutionm.net/forums/sh...d.php?t=300454
Here is more info on it:
https://www.evolutionm.net/forums/sh...d.php?t=297825
Are you sure you have boost leaks? Your traps (121-122mph) look very nice for 22PSI and pump gas, there are plenty of 50trim owners who would take your traps on pump gas and 22PSI. I mean 400whp (on AMS dyno) and your traps pretty much line up in my opinion. I mean you don't even have a boost controller and I am assuming no meth, so your traps are pretty respectable. Some shifting improvements should easily get you in the 11s and with race gas and improved shifting you should be deep in the 11s. I know maybe you were expecting like 420-430whp on the dyno, but AMS dyno reads lower than other dyno jets. I mean damn if you do indeed have boost leaks, then you may have one of the strongest 50trims I've seen.
Hey man. I was at irp a couple weeks ago and saw you race. Loved your car. Honestly it always seems as if people run lower times then they want there.
You had 2-step, correct? I could definenly see you in the elevens, but im no evo expert. Good luck, your car was really quick. Ill come up to you sometime. I want to see your car closer up.
