Going for the Record! Stock turbo, Pump gas!
Tomarrow is the day. Its been a week since I ran 11.29 @ 119.45. The Record was set 2 years ago by Mike1023 going 11.27 @ 120, in an Evo 8 that weighed 2800lbs w/o him in the car with him it was 2960 from what I read. I WILL have a better camera and will do a walk around of the car. Showing how street stock the car is. Both crash beams are in and the interior is fully in the car. it weights 3230 with me and a 1/4 tank. All I need is .03 to break the record. This car is fully UNsponcered and tuned by a friend.
This was last weeks times:
https://www.evolutionm.net/forums/dr...1-2-119-a.html
11.00-11.99 list....He is in RED that shows the record.
https://www.evolutionm.net/forums/dr...1-99-list.html
Here we go!
Here we go!
Thats one of the things that im going to have done IF I cant do it the way it is. I have a few other things im going to get over the winter and see if I can get into the 10's. A bit more power and that 4th gear shouldnt have an issue getting the 3 tenths out to go 10.9x.
Here we go!
Here we go!
After looking at the numbers you are in the 430-450 crank HP range based on the 3230 lbs weight with driver. Now I know why the stock turbo in the Evo X's doesn't get you as far as even 450 crank HP would only net 11.8 @ 115 or there abouts due to the 3700 lbs+ weight with driver. This is all assuming pump gas, I don't think anyone has beat that ET and trap on an Evo X stock turbo yet without using race gas or NOS.
Good luck with the pump gas record for the Evo 8/9!
https://www.evolutionm.net/forums/drag-racing/444538-stock-turbo-full-weight-pump-gas-11-2-119-a.ht
Here we go!
Here we go!
. Good luck. btw, are you using drag radials or slicks? that would be another record on its own.
what record are you exactly going for? so many people have there own idea of what record they are breaking. Are you going for the stock block, pump 93, stock 9 turbo record? Fyi, e85 is just a much pump gas as 93 oct is. Hence, they both get PUMPED from da machine into your car.
. Good luck. btw, are you using drag radials or slicks? that would be another record on its own.Last edited by BURNALL_4; Sep 9, 2009 at 11:00 AM.
06MREvo
Jan 21, 2017 08:43 AM
B.J.@ToxicFab
Apr 23, 2014 05:52 PM
PATRICK B.
Nov 5, 2013 11:37 AM
RyuEvoIX
Oct 15, 2012 08:35 AM
06MREvo
Jan 11, 2012 12:20 PM
block, computerized, drag, evo, evolutionm, gas, ix, pump, pumpg, quote, record, stock, traps, turbo, turbocharged
