Wheel offsets with AMS small brake kit
I'm wondering what size wheels and what offset are people running with the AMS small brake kit front and rear! ie, 15x7 et 45mm, 15x6 et 38mm
I don't want to run spacers!
Thanks.
I bought these Centerline Qualifiers from a fellow member, the rears stick out to far, and I don't want to trim or roll my fenders, the fronts when torqued down with the 20mm spacers on the wheels would not turn!
Thanks.
Ya it depends on the wheel!
I too run the Rota in 15x7 +35 w/ a H&R 20mm spacer (Thanks Em i got the specs from him a year or two ago)
If the Rota's design was a bit different i'd be much happier NOT using the spacer but i also can't drop $400+ per wheel
I'm trying to decide between the Volk CE28n's and SSR type C. The Centerline's weigh 12lbs not too bad. We have a CNC, so I can machine the rears to tuck in a little more, but I don't like 20mm + spacers.
Did you get those Centerlines from Axion 1320?
Unless you can find Motegi's that are light but still require a small spacer i believe (you can ask Mike@AWD or Brian Most-Wanted)..........you gotta pay the piper to get something that looks great and fits perfect like what William, Emery, and Tom Powell have on their Evos (all Volks).
Keith
Trust me man... I'm not a baller. The only way I can afford to buy my parts is because I do all my own work (except tuning). If I had to pay someone to do my mechanic work, there is no way I could have finished this car. You must have forgot I'm in the Marines. I get paid the same as you.
EVOlutionary
13
May 2, 2016 08:48 PM
Vizzle
27
Apr 17, 2015 12:13 PM
FL_SilverEvo8
Oct 4, 2013 10:25 PM
