Top 20 Fastest/Quickest Stock Appearing Turbos for 2013!
#166
My evo again, 63mm turbo. 13.4:1cr race engine and keep the intake / exhaust manifolds and tbody stock.
I decided to use vp import race fuel instead of methanol for this event.
we had 730-750hp at the flywheel at 30psi falling to 26psi at high rpms with this fuel. (With methanol and 36psi we had 805whp that we will test in next event)
We saw a lot of backpressure of the stock exhaust manifold thats why we keep the rpms lower. The turbine wheel can support power till 9000rpms, the engine also is built for 10500.
We manage the 9.5sec and ~150mph pass with 1.52 60ft
I tried to make another pass at 33psi but we had 9.8 sec as the 60ft was 1.78sec.
Please upgrade the list
i hope in next month to get something better.
#172
Dsmguy86 / 5 Oct 2013 / English Racing Tuned / Evo 8 / Stock Block, S2s, Map EF3 E85, stock trans. Exedy triple ,(gutted trunk,street tires ( Hankook V12 255/35/r18 / 11.671 @ 127.75MPH ( blew my axels at the end of the run, unsure if axels or what but I have grease coming out of the axel boots on both sides and I can barley steer
#177
