Top 20 Fastest/Quickest Stock Appearing Turbos for 2013!
List is open to FP White, FP Green, FP Red, FP BLACK, BBK Series, HKS 7460R, ATP turbos, MAP EF Series, ATP Turbos (Australia), Extreme Tuners Turbos Powered Cars ONLY!!
Time slip or at least break down of the time slip is required!!!
All passes must be to the 100th in both MPH and ET (ex 10.03 ET or 123.55 MPH) but to the thousandth would be ideal.
Here is the lists format again...
Screen Name - Date - Shop Affiliation - Evo Generation - Engine/Turbo Setup - ET/MPH
2008
https://www.evolutionm.net/forums/dr...os-2008-a.html
2009
https://www.evolutionm.net/forums/dr...os-2009-a.html
2010
https://www.evolutionm.net/forums/dr...os-2010-a.html
2011
https://www.evolutionm.net/forums/dr...os-2011-a.html
2012
https://www.evolutionm.net/forums/dr...os-2012-a.html
2008
2009
2010
2011
2012
List 1 (Evo VIII & IX) - Best E.T. in the 1/4 mile - Updated 12/31/13
NAME / Date / Main Sponsor / Evo Type / Setup / ET
1. Canexican / 11/3/13 / TPG Tuning, FP, CB Racing / Evo 9 / FP ZERO, CB 2.3 ltr, C16, Shep 5spd, Slicks, Weight Watchers / 9.51ET
2. Stamatis evo6 / 9/16/13 / Extreme Tuners / Evo 6 / ET BB 63mm, Built 2.0L, stock intake mani, exhaust mani, TB & trans, VP Fuel, M&H 235/60/15 tires, 25psi / 9.552ET
3. Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 9.870ET
4. AreSTG / 11/16/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.4L, e85, QTP's / 9.991ET
5. TheKidd113 / 8/24/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, e85, Hoosier DR's / 10.1942 ET
6. PrimerSdime / 5/22/13 / Evo 8 / FP BLACK, stock block, Kelford 272's, E85, QTP's, stock transmission / 10.226ET
7. 1RedEvo / 2/10/13 / ATP Turbo / Evo8 / ATP GTX3576R, Built 2.0L, E85, stock ecu, QTPs, 37 PSI / 10.361ET
8. jezzy101 / 8/18/13/ Iveytune / Evo 9 / FP BLACK, 2.4, tuned by Sean Ivey, E85, Hoosier DR's / 10.548ET
9. 5LEEPERISAH23I / 6/21/13 / TSComptuned / Evo 9 / FP BLACK, TSC 2.4L, Stock ECU+SD, e85, Street tires, 3345lbs, 630WHP VD / 10.654ET
10. fabcas311 / 2/1/13 / JMS tuned / Evo 8 / FP BLACK, MAP 2.0, stock trans, comp stge 4 clutch, gutted trunk, street tires / 10.741ET
11. rong / 8/18/13 / Buschur tuned / Evo 8 / FP RED, Buschur 2.3 liter w/ mivec built head, M3 cams, AEM, Hoosier QTP/RX7 rims / 10.775ET
12. john ix greece / 6/8/13 / Evo 9 / MAP-EF4, Built 2.0, pump gas+meth, 60ft-1.66 / 10.854ET
13. raasfaas / 10/13/13 / Speedshop(Jamaica) / Evo 9 / FP RED, Stock Block, S2's, Street Tires / 10.906ET
14. maknuge / 9/1/13 / MDR Tuned / Evo 9 / FP BLACK, stock block, e85, street tires / 10.980ET
15. 420a-t / 7/6/13 / Evo 8 / FP BLACK, stock block, comp 280, JMF SMIM & O2, 3" TBE, ECMLink V3, Hallman mbc, 600whp VD / 10.994ET
16. itsmrrizz2you / 12/7/13 / TCOMPtuned / Evo 8 / FP BLACK, Built 2.0, c16, 3380lbs, street tires / 11.48ET
17. sinople1 / 10/1/13 / Strictly Modified Tuned /Evo 9 / BBK FULL, Stock Block, Head, Cams, Full Weight, E85, Supporting Mods / 11.549ET
18. TJO3VIII / 9/21/13 / Evo 8 / FP GREEN, SHEP STG2 TC, HKS 272s, Stock block, intake mani & tb, ported stock exhaust mani, 28psi, 110 oct, street tires, 3200lbs / 11.647ET
19. 90zcrex / 9/6/13 / Self built/tuned / EVO 9 / FP GREEN, Stock block, head & cams / 11.670ET
20. Dsmguy86 / 10/5/13 / English Racing Tuned / Evo 8 / MAP-EF3, Stock Block, S2s, E85, stock trans, Exedy triple, gutted trunk, 18" street tires / 11.671ET
List 2 (Evo VIII & IX) - Fastest MPH in the 1/4 - Updated 12/31/13
NAME / Date / Main Sponsor / Evo Type / Setup / MPH
1. Canexican / 11/3/13 / TPG Tuning, FP, CB Racing / Evo 9 / FP ZERO, CB 2.3 ltr, C16, Shep 5spd, Slicks, Weight Watchers / 154.05MPH
2. Flyin_banana / 12/14/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 151.78MPH
3. Stamatis evo6 / 9/16/13 / Extreme Tuners / Evo 6 / ET BB 63mm, Built 2.0L, stock intake mani, exhaust mani, TB & trans, VP Fuel, M&H 235/60/15 tires, 25psi / 148.33MPH
4. AreSTG / 11/16/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.4L, e85, QTP's / 144.69MPH
5. TheKidd113 / 8/24/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, e85, Hoosier DR's / 141.82 MPH
6. 1RedEvo / 2/10/13 / ATP Turbo / Evo8 / ATP GTX3576R, Built 2.0L, E85, stock ecu, QTPs, 37 PSI / 138.44MPH
7. PrimerSdime / 5/22/13 / Evo 8 / FP BLACK, stock block, Kelford 272's, E85, QTP's, stock transmission / 138.27MPH
8. 5LEEPERISAH23I / 6/14/13 / TSComptuned / Evo 9 / FP BLACK, TSC 2.4L, Stock ECU+SD, e85, Street tires, 3345lbs, 630WHP VD / 137.30MPH
9. maknuge / 9/1/13 / MDR Tuned / Evo 9 / FP BLACK, stock block, e85, street tires / 133.59MPH
10. 420a-t / 7/6/13 / Evo 8 / FP BLACK, stock block, comp 280, JMF SMIM & O2, 3" TBE, ECMLink V3, Hallman mbc, 630whp VD / 133.09MPH
11. john ix greece / 6/8/13 / Evo 9 / MAP-EF4, Built 2.0, pump gas+meth, 60ft-1.66 / 132.88MPH
12. raasfaas / 10/13/13 / Speedshop(Jamaica) / Evo 9 / FP RED, Stock Block, S2's, Street Tires / 132.86MPH
13. itsmrrizz2you / 12/7/13 / TCOMPtuned / Evo 8 / FP BLACK, Built 2.0, c16, 3380lbs, street tires / 132.19MPH
14. Gotwheelhop / 1/24/13 / Evo 8 / FP BLACK, 2.3 stroker, English Racing tune, 29psi / 132.11MPH
15. fabcas311 / 2/1/13 / JMS tuned / Evo 8 / FP BLACK, MAP 2.0, stock trans, comp stge 4 clutch, gutted trunk, street tires / 132.00MPH
16. rong / 8/18/13 / Buschur tuned / Evo 8 / FP RED, Buschur 2.3 liter w/ mivec built head, M3 cams, AEM, Hoosier QTP/RX7 rims / 131.64MPH
17. jezzy101 / 8/18/13/ Iveytune / Evo 9 / FP BLACK, 2.4, tuned by Sean Ivey, E85, Hoosier DR's / 129.21MPH
18. Dsmguy86 / 10/5/13 / English Racing Tuned / Evo 8 / MAP-EF3, Stock Block, S2s, E85, stock trans, Exedy triple, gutted trunk, 18" street tires / 127.75MPH
19. sinople1 / 10/1/13 / Strictly Modified Tuned /Evo 9 / BBK FULL, Stock Block, Head, Cams, Full Weight, E85, Supporting Mods / 121.46MPH
20. 90zcrex / 9/6/13 / Self built/tuned / EVO 9 / FP GREEN, Stock block, head & cams / 120.36MPH
List 3 (Evo X) - Best E.T. in the 1/4 mile - Updated 11/08/13
1. BlueX / 4/07/13 / ATP Turbo / Evo X / ATP GTX3582R, pistons, rods, cams, E85, Hoosier DRs, 38 PSI / 10.579ET
2. Mr.Move /10/25/13 / E-Spec / Evo X / Blouch-E-Spec Prototype Turbo, stock block & stock head, 93oct / 11.718ET
3. Hiboost / 6/23/13 / STM / Evo X / TD05H-20G, Stock 2.0, Standard Bolt-ons, Self Tuned, 93 oct, 26 psi / 11.758ET
4. MR:PartyPete / 5/24/13 / Boostin Performance / Evo X / FP RED, Stockblock, 93oct / 12.105ET
5. Joeyhauser / 3/31/13 / Speedcircuit built-Hollywood_x tuned / Evo X / FP RED, built 2.2L, 91 oct, all season-winter tires / 12.245ET
List 4 (Evo X) - Best MPH in the 1/4 mile - Updated 11/08/13
1. BlueX / 4/07/13 / ATP Turbo / Evo X / ATP GTX3582R, pistons, rods, cams, E85, Hoosier DRs, 38 PSI / 138.35MPH
2. Hiboost / 6/23/13 / STM / Evo X / TD05H-20G, Stock 2.0, Standard Bolt-ons, Self Tuned, 93 oct, 26 psi / 117.09MPH
3. Joeyhauser / 3/31/13 / Speedcircuit built-Hollywood_x tuned / Evo X / FP RED, built 2.2L, 91 oct, all season-winter tires / 115.69MPH
4. Mr.Move /10/25/13 / E-Spec / Evo X / Blouch-E-Spec Prototype Turbo, stock block & stock head, 93oct / 113.94MPH
5. MR:PartyPete / 5/24/13 / Boostin Performance / Evo X / FP RED, Stockblock, 93oct / 107.59MPH
List 5 (Ralliart) - Best E.T. in the 1/4 mile - Updated 12/31/13
NAME / Date / Main Sponsor / Setup / ET
1. Rahtid / 12/20/13 / 09 RA / FP RED, Stock block, Jester tune, 27 psi / 12.238ET
2. silthos / 1/27/13 / 09 RA / FP RED, Stock block, Hollywood tune, 27.5 psi / 12.400ET
3.
4.
5.
List 6 (Ralliart) - Best MPH in the 1/4 mile - Updated 12/31/13
NAME / Date / Main Sponsor / Setup / MPH
1. silthos / 1/27/13 / 09 RA / FP RED, Stock block, Hollywood tune, 27.5 psi / 114.32MPH
2.Rahtid / 12/20/13 / 09 RA / FP RED, Stock block, Jester tune, 27 psi / 113.55MPH
3.
4.
5.
3.
4.
5.
3.
4.
5.
Will a MOD/ADMIN please sticky this thread & un-sticky the 2012 list?? Thank you!!!
Also congrats to everyone on the list last year!!
Emery @ STM went the quickest with a 9.436ET @ 147.01MPH....This was on STOCK BLOCK TOO!!
Flyin_banana went the fastest, trapping 147.964MPH with a 9.742ET
Nice job guys!!! Good Luck to everyone this year!!
Guess I'll toss in here first.
Gotwheelhop / 1-24-13 / Evo 8 / 2.3 stroker, FP BLACK, English Racing tune, 29psi / ET 11.743 w 2.0 60ft.
Gotwheelhop / 1-24-13 / Evo 8 / 2.3 stroker, FP BLACK, English Racing tune, 29psi / 132.11mph
Slip breakdown -
R/T - 1.182
60' - 2.063
330 - 5.394
1/8 - 7.913
MPH- 95.61
1000 - 10.027
1/4 - 11.743
MPH - 132.11
Slip breakdown -
R/T - 1.182
60' - 2.063
330 - 5.394
1/8 - 7.913
MPH- 95.61
1000 - 10.027
1/4 - 11.743
MPH - 132.11
Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 9.870 ET
Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI /147.003 mph
