CLOSER TO THE 8's!
TrevTec Motorsports here in Las Vegas does all the work on this car!
He build the motor 7 years ago,
a 2.1 low comp 4g64
regular arp headstuds
7 yrold BC Cams,
7 yrOld unknown costum Intake Manifold
Sheepey FF 6466 kit
7 yrold Costum fuel system A1000, recently replaced to a Aeromotice Eliminator black1
FIC 2150
QM 8leg
stock trans, just change 2nd gear syncros once in a while when they go out!
Tune with a 7yrold POWER FC COMMANDER!
Last year took the oil pan off and changed rod bearings just to be safe! More boost was
Coming.
Thats the only time the motor has been touch, head has never been open for those 7 years, never has lifted. No PP, just valve train and cams!
a 2.1 low comp 4g64
7 yrold BC Cams,
Sheepey FF 6466 kit
FIC 2150
QM 8leg
Coming.
Your car is moving out man!
Quick question, nvm, I'll just text you!!!
Once again congrats bro, your knocking on 8's door, now get that stuff we talked about and nothing else stands in your way!!!
On the 9.1 pass i dint use no 2step i just slip the clutch rev to about where i see 8k rpm and LET GOO! but when i compete, 2step is set 7k rpm witht the MSD digital1 15psi in a second consistent 1.4xx 60fts ussually also get .0xx R/Ts
Before the 9.1 pass i ran the first pass of the day a 9.20 pass and it was with 2step, but spun a little so got a 1.505 60ft, let me try and see if i can get that video somewhere!
Thx bud
Temp is fine when the car is driven around, Fluidyne been there for about 7 years no issues either, with just 1 fan!
Congrats on the time man! Car is deff movin!! In my opinion you should go with a small brake kit & a 15" rim! It'll make a huge difrence! &. I'm more than positve you'll crack Into the 8's just with that change. If you don't want to do the small brake kit. Then I'd look into atleast the fd wheels, it's a smaller & lighter wheel. & you can still use the stock brakes. But the small brake kit will make a big difrence man. Best of luck on what ever you decide to do.
