Wanted to share my results from the 1/4 mile yesterday.
06 Evo SSL
57k miles
E85
Essentials:
Stock bottom end, stock trans and stock t case
Ets v band turbo kit
Pte 6466 gen 2 dbb turbo
Kelford 272 cams
Gsc springs and retainers
Full bolt ons
I can provide a full list if anyone cares...
Tuned by Kasey Harris at Dyno Time speed works
This was the first pass of the day and first pass ever on these tires. I had my best 60’ on the next pass and almost got into the 6s 1/8 Mile but missed 4th gear. Was so mad. Probably would’ve been my 10.5-10.6 I wanted. This is on a comp stage 2 clutch and I think when it gets hot the shifting gets really notchy for some reason. Need an exedy twin disk and a shep trans so I can bang the gears and run a low 10.
I wouldn't worry about it on the slicks. Slicks and a 1.6 60 ft should be fine for stock drivetrain. The soft sidewall of the slicks will help absorb the initial shock.
- Robert
__________________
Michael
Pho: 360-896-3000
AIM: ETS MichaelR
Evo 8/9/X Intercoolers, Intakes, Piping Kits, Exhaust Systems, Manifolds, Downpipes, Test Pipes and Turbo Kits
I wouldn't worry about it on the slicks. Sicks and a 1.6 60 ft should be fine for stock drivetrain. The soft sidewall of the slicks will help absorb the initial shock.
- Robert
Thanks!
Yes going to try and make it back either later this month or early next month and get a low to mid 10!
Using slicks will impose more risk on damaging the drivetrain because you have instant traction, therefore, rather than dissipating the energy thru wheel slip, it will transfer into the drive-line components and clutch slippage.
Slipping the wheels is a good thing for the drive-train!
I've heard it go both ways. Tire slip can cause wheelhop or shock the drivetrain when it finally catches while slicks absorb that shock. But slicks provide a bunch more traction. I don't really know lol all I know is these damn Evos are a hell of a lot harder to cut a good 60' versus the DSMs that I'm used to.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
