-   Drag Racing (https://www.evolutionm.net/forums/drag-racing-16/)
-   -   If youre in the 11's and running stock turbo.... (https://www.evolutionm.net/forums/drag-racing/148673-if-youre-11s-running-stock-turbo.html)
Sap12687 Jul 14, 2005 07:15 PM
i need to see your setup....please :)
4ringturncoat Jul 14, 2005 07:18 PM
Check my sig. This was done on the old turbo (9.8).
tke_413 Jul 14, 2005 07:24 PM
I'm almost positive I'll hit 11's the next time out...I just haven't gotten the tune done for the new mods. Here's the performance parts I've added to the stock turbo...
GSC 264/264 cams (if you don't have these...GET THEM!)
Injen intake with upper i/c piping
Walbro fuel pump
10.5 Hotside
Tubular Header
3" o2 housing
3" downpipe, high-flow cat, cat-back
Greddy profec-b EBC
Nology Hotwires, 1 step colder iridium plugs
MR diverter valve
ACT street clutch kit
TurboTrix flash/tune
Parts on the way: Lower i/c piping, 680cc injectors, SS clutch line, AEM fuel rail, new tires
Sap12687 Jul 14, 2005 07:34 PM
hmm...keep them coming
DSMotorsport Jul 14, 2005 07:58 PM
I did it once last fall with the stock 03 turbo.
1.712 (off my normal times by .05)
4.972
7.672
91.37
9.975
11.950
114.18
bogged the launch just a little...normal 1-2 shift powershift 2-3 3-4
22psi dropping to 20 by 7000rpm
116 sunoco racegas
3" VRS turboback exhaust with testpipe
2.5" cold air intake (air filter where the stock ic sprayer tank was)
AEM EMS speed density, AEM wideband, Autometer boost gauge
ACT clutch
Walbro 255 pump
Hallman es manual boost controller
1g DSM bov
all the ususal...same mods as last week, with the addition of a spearco "drop in" FMIC core. The info on the logs shows that the FMIC core wasn't doing shat. Intake temps after the intercooler are 15-20* hotter than with the stock FMIC. It was colder tonight than on sunday last week and I was running the same boost pressure. IMHO an intercooler upgrade on an evo8 is completely worthless on the stock turbo..atleast in cool fall weather.
TrinaBabe Jul 14, 2005 08:15 PM
I agree with you on the intake temps being the same or maybe even a little warmer... I dont know but I can easily see it happening with the stock turbo. The one thing i did notice when I switched the IC when I had the stock turbo was the spool up was increased by a decent amount. Maybe it was all in my head as I have no logs but it really seemed to make a big difference.
EvilDylan Jul 15, 2005 06:01 AM
i ran 12.0 @ 117 with the mods in my sig.
and now ive got cams so im sure ill be in the 11s.
GOKOU Jul 15, 2005 06:25 AM
Just curious but how did you get a trap speed of 117 with only those mods??
Also how does one go about getting 1.7, 1.6 60 ft times without breaking the car?? :lol: :lol:
Warrtalon Jul 15, 2005 06:27 AM
Wow, 117mph without cams? I don't think anyone else has done that. The fastest I've seen is the 115.8 on an 05 with open exhaust and some extreme tuning that caused a big controversy in the drag racing forum. 117 blows that away, so you gotta be the fastest stock cammed Evo in the country...
Also curious how you're good enough to cut a low 1.6x 60', but unable to hit 11s on 117mph. 12.09@117 indicates a 1.9 or 2.0 60' or a completely missed shift. With a 1.62 60', you would expect a 11.6 or 11.7 at that mph...
This means that with TBE/Intake/MBC/Fuel Pump/Cam Gears/Ecu+, you gained 150whp over stock. That's the sort of thing legends are made of...you should be out there making tons of money, because no tuner I know of can mimic that.
4ringturncoat Jul 15, 2005 07:03 AM
Was it 40 degrees out and a 90mph tailwind? How many other 117's have you had? 91 in @ 660 was the best then getting to 117 on a stock turbo and ecu - cams seems pretty amazing!
EVOMIZ Jul 15, 2005 07:11 AM
272 CAMS ,AEM EMS , 3in TURBOBACK, 660CC
255 PUMP,TURBOXS FMIC,INTAKE ,ACT CLUTCH,WORKS TB
FLYWHEEL
TURBODAWG Jul 15, 2005 07:15 AM
I have run three times (with cams and stock FMIC) to 118.1, 118.4, 118.7 mph. The 1/8 mile MPH were 89.1 to 89.4 mph on those runs. The best time that night was 12.24@ 118.4 mph. It was about 45 degrees on a slick track. My 60' time was 1.859 on the 12.24 run. I was picking up about 29 mph from the 1/8 mile traps to the end of the 1/4 mile.
The 117 mph run was definitely a strong run for no cams. Did you have cam gears at that time?
Brian
ArchieBabes Jul 15, 2005 07:42 AM
11.8 @ 122mph
Stock unported 03 9.8 Turbo
Stage 4 Parts
Check my sig
DCSilvrEvo Jul 15, 2005 07:53 AM
I cut a 1.69 first time @ the track with my evo. I ran 12.5@108 and thats because i was untuned. That was also on all season street tires...
Warrtalon Jul 15, 2005 08:13 AM
Brian
Don't forget, that's at downhill Rockingham. I used to get those 113+ mph times that I mentioned on my other thread on a 1G with a small 16g/FMIC/SAFC on a stock, original engine with 100k+ miles. I never hit 113mph at any other track, though. 360whp on a Dynojet is not enough for over 118mph, so I think the track was running fast while being slick, just like what I experienced when I used to go there (never could hit a 1.6x 60'). If I can hit 12.22@109.2 on a 1.75 60' while you hit 12.24@118.4 on a 1.86 60', I think there is an obvious factor involved there that comes down to the track itself. If you give me a 1.86 60' but an extra 9mph, I'm going to be in the 11s easily, no doubt.
Brian, have you run 118+ at tracks other than Rockingham? I haven't read enough of your threads to know for sure. If these MPHs are at a different track, then disregard, but I think I recall you saying these were at Rockingham...
Oh, I almost forgot. Gaining 29mph in the back half on a stock turbo is INSANO!! Wow, that's gotta feel like a raped ape, because that's the sort of stuff GT35Rs do. I was hitting the same 1/8th-mile MPH as you (88.6-89.5) on my little set of mods, but I was only gaining 22-23 in the back half...
