-   Drag Racing (https://www.evolutionm.net/forums/drag-racing-16/)
-   -   Best cam gear settings for 272's at the stip? (https://www.evolutionm.net/forums/drag-racing/168888-best-cam-gear-settings-272s-stip.html)
rACerS Nov 10, 2005 07:42 PM
I was just wondering what you guys are running your cam gears at. And laugh if you want, but if your standing at the passenger fender the intake cam is on the left and the exhaust on the right. And if you turn the cam gears to the right that would be advancing them?
Right now mine are turned 3 to the right, and 1 to the right of straight up. So would that be +3,+1?
Most I have read about cam gears and 272's is to run them at -4,-1 or -3,-3. So if Im at +3,+1 that would mean more bottom end and less top end right?
So im hoping that changing these settings will get my mph up some. Im headed to the track this friday and would like to try some different settings. So will changing the cam timing affect your afr's?
thanks
Warrtalon Nov 10, 2005 08:16 PM
I don't know the specifics of how/why it works like this, but my buddy with 272s on his MR has the cam gears set to -4/-1, and he has a lot less low-end/mid-range power, but he has very nice top-end power as proven on the dyno. With these settings, he was able to trap 113.9 on pump gas the same night I hit my 12.01 and trapped 113.7 on race gas. Now, I don't have cams, but he still outrapped me despite being an inexperienced drag racer. He only hit a 12.6, but nailed right at 114mph on pump, which I think is a testament to the -4/-1 setting at the dragstrip. This was also at normal street boost of 21psi. We look forward to tossing in some race gas, cranking the boost, and leaning out the SAFC to see if he can hit 117mph. You can probably do the same with -4/-1 on the cam gears...
rACerS Nov 10, 2005 08:40 PM
thanks I will try the -4,-1 I will just have to figure out which way is - ahah
gkania Nov 11, 2005 09:53 AM
You would turn the cam to the left 4 clicks before 0 and 1 click before 0 looking from the passenger side. Just imagine you are looking at a number line.
-5 -4 -3 -2 -1 0 1 2 3 4 5
I
I
The line should be here for -5, I cant get it to stay by the four :)
rACerS Nov 11, 2005 04:58 PM
Thanks that helps a bunch {thumbup}
matt55 Nov 13, 2005 08:01 AM
I like -4/-1.5 with 272's
Nesiop Nov 13, 2005 08:15 AM
I thought you needed some kind of tool to measure cam gears, or the dyno in order to just "turn the Gear" without taking a chance of damage. Or are cars for cam gear timing the same for all evos where as the tune is different for every car. Cause I am about to put in cam gears next week but was going to leave them at 0 0.
rACerS Nov 26, 2005 08:48 AM
Big thanks Matt, those settings worked great. {thumbup}
Noize Nov 26, 2005 06:24 PM
Careful changing cam gear settings without remapping. It can cause lots of problems like detonation. I like -2/-1 the best.
Warrtalon Nov 26, 2005 06:33 PM
He switched to -4/-1.5 and went from 114.5mph to 119.5mph, so I guess it worked pretty well...
DSMotorsport Nov 26, 2005 07:03 PM
I have my gears set to -4/-1 and my stock 03 turbo is making much better high rpm power than I was expecting: about 385-390whp and it holds 375+whp from 5700rpm till 7700rpm. Im expecting the car to run 117mph on 93 pumpgas. no meth.
I haven't had time to experiment with other cam gear setting other than 0/0 and -4/-1 and the retarted settings seem to make significant high rpm gains.
pharmd98 Nov 26, 2005 07:07 PM
Sorry to interrupt but anybody found a good setting for 280 cams?
Warrtalon Nov 26, 2005 07:25 PM
What is allowing you to make ~390whp on the 03 turbo without alky, race gas, or nitrous?
vboy425 Nov 26, 2005 07:28 PM
i would say AEM EMS and Nitrous {thumbup}
Blue Evo 8 Nov 26, 2005 07:28 PM
GT35R
