Need help on improving my IX's times.
Car # 732
This run was done last friday and I was not really prepared. I might go back this Friday so I need some coaching. Car is IX MR with full tank of gas and no weight reduction. Tires pressure i 36f 33r. All runs was done with normal/full lift shift. 1st run - shifting at 6500rpm. 2nd run - shifting on 7000rpm except for 1st gear. I had to shift early, the car went sideways because my tires were wet - they probably thought the car is FWD. 3rd run - had to back out of 1st gear because of slight wheel hop, shifting at 7500rpm. What rpm do you guy shift when drag racing? What time should I expect? https://img205.imageshack.us/img205/...can00028zg.jpg |
No timeslips.
You need to shift at 7000rpm and should expect a 12.9-13.1 in stock form, and low 12s with Warrtalon Stg 1 equivalent mods. Don't go with a full tank - that's senseless. Remove your spare, jack, and tools. |
Good Job.
I doesn't seem like you need to improve that much. Shift at 7000-7200. |
ur times are fine
is ur car stock? if it s its doing what it s supposed to do. just need to work on your 60' practce launching and u ll run much better |
Originally Posted by matt55
What is the mph on 2nd run , it looks like 108 mph ?
60' is whats killing u...learn how to launch and get the tire pressure right and you'll be in the 12's.
wait.. was that 108mph your speed?
He's not stock; he just hasn't listed his mods.
Mods on this car: drop-in filter / cat-back / V4-dynoflash
Does Anyone Shift Off The Rev Limiter(7800rpm)
WHEN IM RUNNIG THE CAR I SHIFT 1ST TO 2ND OFF THE LIMITER BECAUSE IT GETS THERE IN A BLINK OF AN EYE, AFTER THAT I SHIFT AT AROUND 7300. AT THAT RPM IT STILL FEELS LIKE ITS MAKING POWER. BR350 ix #005
and thats with the stock cat. These cars are amazing
| All times are GMT -7. The time now is 11:55 PM. |
