-   Drag Racing (https://www.evolutionm.net/forums/drag-racing-16/)
-   -   Went to the track!! (VIDEO'S INSIDE) (https://www.evolutionm.net/forums/drag-racing/235596-went-track-videos-inside.html)
ant_turbo Nov 18, 2006 01:45 PM
7.78 1/8 mile
Got a LIL sideways in the burnout box.
My Other Run
4WS Tuning Nov 18, 2006 01:58 PM
y would u try to do a burn out... ur just messing up ur clutch for no reason..
if u were spinning through first and second okay... but thats just pointless
Spec'd Nov 18, 2006 02:09 PM
Was that Irwindale Speedway ?
ant_turbo Nov 18, 2006 02:19 PM
1st I have a upgraded clutch!!.. 2 sec I have have seen a difference between just rolling passed the burnout box and doing a quick launch to clean off the tires!!
Because at IRWINDALE SPEEDWAY they really like to spray alot in the burnout box..
Gonzo0991 Nov 19, 2006 10:46 PM
mods?
clarkkent06 Nov 19, 2006 11:03 PM
vid's not working...but can you drive around the burnout box and avoid getting that crap on your tires? i know at PR in washington you can drive around the box
scott yo Nov 19, 2006 11:05 PM
aint working for me either!
Danny23 Nov 19, 2006 11:57 PM
island dragway and englishtown also for driving around the burnout box.
ant_turbo Nov 20, 2006 01:37 AM
255FP/HKS FILTER WITH INJEN INTAKE WITH UICP/TBE/MBC/ACT HDSS....And every time I race I use race gas 100/103...
And you can't really drive around the burnout box!! You will still endup driving in it!!
Originally Posted by Gonzo0991
mods?
ant_turbo Nov 20, 2006 01:46 AM
There working now!!
SKILMATIC Nov 20, 2006 11:38 AM
can you post your stats of the time slip? very nice run btw.
ant_turbo Nov 21, 2006 10:41 PM
Sorrry there in the trash,,,
eve-slow Nov 21, 2006 10:45 PM
Looks like fun.
dsmfan95 Nov 23, 2006 02:40 AM
The 1/8th mile tracks around here suck. You pick up rocks and other stuff rolling through the staging lanes, so rolling through the water box and cleaning off the tires helps.
nvr2fast Nov 23, 2006 05:47 AM
Nice!
What launch technique did you use? I hear you bouncing off the rev limiter, did you set it to 6000rpm? Sounds a bit lower at 5000rpm?
And on green, did you basically floor the throttle and dump the clutch, or did you do something different?
Warrtalon recommends i think 6000rpm and letting the clutch out quick (not dumping), but on my Evo IX, if i do that the clutch just slips (yes i'm on stock clutch). I find if I set the rev limiter to 5000rpm, i still dont bog but I dont get too much clutch slippage either. I am guessing because the IX has more torque perhaps? I tried 3000rpm that doesn't work. I have yet to try 4000 or 4500rpm, but I suspect it may bog.
