11.5's possible with my setup?
My goal is to run 11.5 on stock evo9 turbo can it be done with my setup.
car is 06 tb evo 9 gsr full weight minus spare tire and jack/tools 18'' wheels aem intake hks 272 mivec cams arp headstuds turbosmart bov walbro 255 turbo xs fmic ams licp greddy uicp hallman mbc @ 30 psi aem alky injection act clutch prolite flywheel 9lb megan manifold megan o2 housing megan tbe reflash im guessing the car will do 400whp+ on a dyno jet, i did 365hp/365/whp with bpu and cams, so with meth im guessin it should be there. ive never ran the car with this set up, im thinking of getting a forge wg to hold more boost at redline but i dunno. i know bench mark racing isnt good. but im wondering if the car has the right mods and power to run a 11.5 |
I would say with a good tune your setup is at least good for like 11.7's...You could probably squeeze a 11.5 if you launch well. aIt's really gonna depend on the driver. I have personally seen some1 go 11.6's with similar mods on a 9 but idk...
G/L {thumbup} :mitsu: :beer: |
Tuned right and driven real well the car should be able to go low 11's.
-Em |
You should have no problem hitting 11.5 with that setup. I was running consistent 11.6's on pump gas stock turbo. Here was my setup.....
The best I could get with bald street tires, spinning thru 1st was...... R/T = .313 60' = 1.755 330 = 4.881 1/8 = 7.490 MPH = 94.09 1000 = 9.729 1/4 = 11.625 MPH = 116.39 Car weighed in at 3070 lbs with a quarter tank, no spare, full interior. With me in it it weighed 3205 lbs. Mods are...... GSC S1 cams, ARP Head Studs, Megan Racing: Tubular manifold, o2 housing, DP, TP, Cat-back, ETS: 3"Intercooler kit, Intake kit, Small battery kit, ACT 6 sprung 6 puck, SS Braided Clutch line, restrictor removed, Buschur Racing shifter bushings Walbro 255 Hallman MBC Stock turbo Good Luck!!{thumbup} :mitsu: __________________ |
put the stock wheels back on, get the wategate and you should have no problems going 11.5
damn thats impressive, what were you boosting at?
and how did you like those cams? |
wow! those are some amazing times for stock turbo on straight pump..
Originally Posted by koffebean00
(Post 5099407)
its possible with your setup but depends on the driver
my brother 4 wheel slide went 11.4 on 19's with a horrible 60' and less mods, breaking up in 4th
hopefully i can cut sum 1.6's
i know about 400whp people start stredding the tires threw first gear so im thinking of going back to the stock rims and get drag radials and get a set of coil overs as well also considering the forge wg, i heard they can hold about 25 psi at redline, i dont know tho. can anyone fill me in>? |
I trapped almost the same as you, but I have only trapped 90.8 in the 1/8 th mile? I am on stock cams still. What rpm do you shift at? I have yet to run at sea level so no idea what I can run down there, but I have run 11.939, but many many many 12.00xxx runs.
(Post 5099407)
I also have the forge WGA but cant hold more than around 20 at redline(7000),I hold 19 at 7600 but thats between 3500-4200 feet. At sea level it should be higher. I have the spring it came installed with. When I go green I may change to the stiffer spring since Ill need a retune anyway. But for a reference I do hold 1.5-2psi more at high rpm w/ the forge as well as a much flatter boost curve.
(Post 5099407)
The best I could get with bald street tires, spinning thru 1st was...... R/T = .313 60' = 1.755 330 = 4.881 1/8 = 7.490 MPH = 94.09 1000 = 9.729 1/4 = 11.625 MPH = 116.39 Car weighed in at 3070 lbs with a quarter tank, no spare, full interior. With me in it it weighed 3205 lbs. Mods are...... GSC S1 cams, ARP Head Studs, Megan Racing: Tubular manifold, o2 housing, DP, TP, Cat-back, ETS: 3"Intercooler kit, Intake kit, Small battery kit, ACT 6 sprung 6 puck, SS Braided Clutch line, restrictor removed, Buschur Racing shifter bushings Walbro 255 Hallman MBC Stock turbo Good Luck!!{thumbup} :mitsu: __________________ I don't think 400whp is good enough for an 11.5 with out some weight reduction and the 18's need to be very similar weight to the stock or that will be a problem. You don't need drag radials at your hp level. I would say with excellent driving ie.... a 1.6 60ft and banging the gears like no other I would expect a 11.7-11.8 at 116 to 117. That would be my guess. That being said with a normal driver with similar mods I see evo's run mid 12's all the time. The driver makes a big difference. |
if u know how to drive its for sure an 11.5 car
Highly unlikely you will hit 11.5s, because that would take some serious driving, but the mods on the car SHOULD be capable of hitting 11.5s in the right hands. The problem is things are not always equal, so just because you have X set of mods and Y amount of WHP on a dyno, it doesn't mean the car will perform well on a drag strip.
As for koffeebean, there's no way that timeslip was done on pump gas unless he refers to 100oct as pump gas or 93+alky as pump gas. I'm sorry, but 7.49@94 in the 1/8th on pump gas with a weak 60' is just not believable. |
| All times are GMT -7. The time now is 06:46 AM. |
