-   Drag Racing (https://www.evolutionm.net/forums/drag-racing-16/)
-   -   Shift Point discussion, 7K or higher for MR's (https://www.evolutionm.net/forums/drag-racing/348461-shift-point-discussion-7k-higher-mrs.html)
Mr. Evo IX May 29, 2008 11:34 PM
I went to the dragstrip last night with my Evo and logged all of my runs. One of the things I wanted to try to discover was what effect using different shift points had on my car. I was able to create an interesting visual from the log.
These HP / TQ figures are derived from airflow/rpm instead of time/distance/work calculations.
2byte rpm values
1st 7558
2nd 7878
3rd 7886
4th 7843
Conventional Evo wisdom, stock turbo doesnt make usable torque above 7K. Airflow may say otherwise. Discuss.
http://www.rgvimports.com/pics/MrEvoIX/shiftpoints.jpg
Carloverx Jun 1, 2008 03:05 PM
Do it again but shift at 7k. Compare the two graphs. Right? I can't wait to see the results
Mr. Evo IX Jun 1, 2008 04:08 PM
The next time I go to the track I'll make sure to get it both ways and I'll update the thread and PM you. Note not all cars have a powerband like mine so this may not change conventional wisdom. I wasnt looking for an argument with Warrtalon in your thread, I'm looking for my ideal shift points too:).
Carloverx Apr 11, 2009 09:06 AM
bump for results haha
C6C6CH3vo Apr 11, 2009 09:00 PM
I get my fastest splits shifting at about 7000. stock turbo
PeteyTurbo Apr 12, 2009 02:38 AM
You look at your dyno chart and go from there:)
Levar Apr 12, 2009 03:40 AM
I'm not going to simply say 7K and that's it. I'm more practical by weighing all of the necessary and required numbers to make the best decision. If you have a dyno chart of your tune available, this website should give you a hand.
http://www.bgsoflex.com/shifter.html
If you need the transmission gear settings for your car, here they are:
Gear Ratios
EVO / EVO RS
1st: 2.785:1
2nd: 1.950:1
3rd: 1.444:1
4th: 1.096:1
5th: 0.761:1
Final Drive: 4.529:1
Gear Ratios
EVO MR
1st: 2.909:1
2nd: 1.944:1
3rd: 1.434:1
4th: 1.100:1
5th: 0.868:1
Final Drive: 0.693:1
Carloverx Apr 13, 2009 07:35 PM
Yeah i hear ya, but my power curve is soooo gradual :crap: but gaining and loosing hp
