1/8 mile time fp red evo IX
went to the local 1/8 mile dragstrip on saturday june 6th....first time running the 1/8 mile, and first time at the track period with this setup
Evo IX (mods in sig) 93 octane Boost 23.6 psi 2 step set at factory level Full weight (minus the spare and car had about 1/2 tank of gas) stock evo x yokahamas 60 ft. - 1.81 330 ft.- 5.16 1/8- 7.93 mph- 87.8 |
Could you post a full mod list, your signature doesn't really show much.
It seems like you're a bit down on power, I would expect like low 90's trap for an average Red setup on pump gas. |
Originally Posted by dsmfan95
(Post 7152524)
It seems like you're a bit down on power, I would expect like low 90's trap for an average Red setup on pump gas. boost was just 23.6 psi....when i was being tuned my fmic was heat soaked thats why the low boost....also numbers were on cbrd's mustang dyno injen intake and uicp, turbo xs fmic, evo power mods licp and 02 dump, gsc s1's, blitz boost controller, 880's, fp red turbo, walbro pump, dc sports 2-1 catless dp, greddy tic cb, ported stock em |
(Post 7152524)
It seems like you're a bit down on power, I would expect like low 90's trap for an average Red setup on pump gas. the RED needs MORE BOOST! |
im not the worlds greatest driver either
damn griffey you aren't having much luck so far with this Red. I'm sure with some better driving you'll bring the time down.
its all in the practice, i remember the first time i raced mine i was neck to neck with modded GTI's, running like 9.2-9.4 in the 1/8th lol
any tips on how to lower my time??? i dunno what im doing wrong
Couple questions....What clutch do you have? Any motor mount? Shifter Bushings? Shift Knob? Engine Damper?
Originally Posted by aka.ralliart15
(Post 7155430)
K well since you have the ACT im sure you are having trouble getting into second gear after the 2-step launch and sometimes into third cause I had the same problem.
Since then i got the shifter bushings and the greddy counter weight shift-knob which allowed me to bang thru the gears a bit easier. I would do those two for now which are relatively not that expensive and see if that makes it any better. then you can get the other two things if you'd like to hold the motor in place. |
For the 1/8, the ET is all in the 60' and the 2 and 3 catch. HP helps but there's only 1/8 mile to launch and shift 2 or 3 times.
In the 1/4 you can make up with HP in 4th. I never ran the 1/4 and haven't been to the 1/8 in several years. But I know the 1/8 is a driver's race (+luck) |
Admittedly we are a little short on the 1/8 track here, and they dont give us 60' times, so , here is my .o2. I have to slip the clutch quite a bit to get a good launch. If you are missing gears, it makes it really hard to get a sub 8 in the 1/8. I can drop from a 7.6-7.7 to an 8.1 with just a hard time getting it in gear. Thanks for the info about the shifter busshings and such, maybe that will fix my problem with shifting.
cat back exhaust K&n intake lightweight flywheel evo ix |
Originally Posted by neonhorse
(Post 7192324)
i want a fp red..... i run like a 8.?
