FP red with crappy launch/e85
Went to the track last night. Got 2 runs as everything was breaking down all night. 1st run I popped out of 1st gear so I didnt run. Second run I bogged hard at the line. Ill post the timeslip soon: 60' 2.1/ 11.38 @ 132.27. I know this was a crappy launch. I have the hoosier Dr's and they hooked and I bogged. 2 step appears to be 6400 rpms. Next time Ill bump it up to 6800rpms. Anyway
Im pleased with the trap speed. I have alot left in the turbo! Cant wait to get back out there. |
great trap speed man {thumbup}.......et was not to shabby either with a 2.1 60ft. Good job bro{thumbup} get out of the hole quicker and you have a 10sec family car.
Mod list? I see you have the FP Red, but what else?
BR 2.0/supertech valve train/comp 280/280 cams/shep trans and t-case/exedy triple/Fpred 84mm inlet/shearer tubular mani/map rev3 IM/65 mm tb/BR double pumper/1200cc injectors/stock ecu/BR IC and plumbing/Hoosier dr's on rpf-1's. I think thats the majority.
Thats moving
Originally Posted by xcelr8
(Post 8115285)
practice more on the launch and you'll nail a 10 sec slip in no time |
VERY nice mph! turn the wick up!
How much boost are you running? 32psi?
Real nice MPH! Nice setup...who tuned it?
yes 32lbs on the defi gauge. i got a omni 4bar i need to install. Junior tuned at turbotrix.
Thanks for the nice comments |
132 trap will def do a ten second pass if you can get the 60 foot down.
Yo man, your drivetrain is fully done up. You should have launch the crap out of it. I have stock t-case and tranny so that is my only excuse of babying my car ff the line. Nice anyway.. Those tires grabs really well which lets alot of people bog anyway.. GL next time
Originally Posted by gsr0801
(Post 8118311)
(Post 8118311)
Yeah I know. The problem was the 2 step is set too low. Im going to bump it up quite some and hit the track up in a few weeks. |
Did you stay in 4th or have to shift into 5th? Anything changed with the gearing?
