Top 20 Fastest/Quickest Stock Appearing Turbos for 2013!
List is open to FP White, FP Green, FP Red, FP BLACK, BBK Series, HKS 7460R, ATP turbos, MAP EF Series, ATP Turbos (Australia), Extreme Tuners Turbos Powered Cars ONLY!! Time slip or at least break down of the time slip is required!!! All passes must be to the 100th in both MPH and ET (ex 10.03 ET or 123.55 MPH) but to the thousandth would be ideal. Here is the lists format again... Screen Name - Date - Shop Affiliation - Evo Generation - Engine/Turbo Setup - ET/MPH 2008 https://www.evolutionm.net/forums/dr...os-2008-a.html 2009 https://www.evolutionm.net/forums/dr...os-2009-a.html 2010 https://www.evolutionm.net/forums/dr...os-2010-a.html 2011 https://www.evolutionm.net/forums/dr...os-2011-a.html 2012 https://www.evolutionm.net/forums/dr...os-2012-a.html |
List 1 (Evo VIII & IX) - Best E.T. in the 1/4 mile - Updated 12/31/13
NAME / Date / Main Sponsor / Evo Type / Setup / ET 1. Canexican / 11/3/13 / TPG Tuning, FP, CB Racing / Evo 9 / FP ZERO, CB 2.3 ltr, C16, Shep 5spd, Slicks, Weight Watchers / 9.51ET 2. Stamatis evo6 / 9/16/13 / Extreme Tuners / Evo 6 / ET BB 63mm, Built 2.0L, stock intake mani, exhaust mani, TB & trans, VP Fuel, M&H 235/60/15 tires, 25psi / 9.552ET 3. Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 9.870ET 4. AreSTG / 11/16/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.4L, e85, QTP's / 9.991ET 5. TheKidd113 / 8/24/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, e85, Hoosier DR's / 10.1942 ET 6. PrimerSdime / 5/22/13 / Evo 8 / FP BLACK, stock block, Kelford 272's, E85, QTP's, stock transmission / 10.226ET 7. 1RedEvo / 2/10/13 / ATP Turbo / Evo8 / ATP GTX3576R, Built 2.0L, E85, stock ecu, QTPs, 37 PSI / 10.361ET 8. jezzy101 / 8/18/13/ Iveytune / Evo 9 / FP BLACK, 2.4, tuned by Sean Ivey, E85, Hoosier DR's / 10.548ET 9. 5LEEPERISAH23I / 6/21/13 / TSComptuned / Evo 9 / FP BLACK, TSC 2.4L, Stock ECU+SD, e85, Street tires, 3345lbs, 630WHP VD / 10.654ET 10. fabcas311 / 2/1/13 / JMS tuned / Evo 8 / FP BLACK, MAP 2.0, stock trans, comp stge 4 clutch, gutted trunk, street tires / 10.741ET 11. rong / 8/18/13 / Buschur tuned / Evo 8 / FP RED, Buschur 2.3 liter w/ mivec built head, M3 cams, AEM, Hoosier QTP/RX7 rims / 10.775ET 12. john ix greece / 6/8/13 / Evo 9 / MAP-EF4, Built 2.0, pump gas+meth, 60ft-1.66 / 10.854ET 13. raasfaas / 10/13/13 / Speedshop(Jamaica) / Evo 9 / FP RED, Stock Block, S2's, Street Tires / 10.906ET 14. maknuge / 9/1/13 / MDR Tuned / Evo 9 / FP BLACK, stock block, e85, street tires / 10.980ET 15. 420a-t / 7/6/13 / Evo 8 / FP BLACK, stock block, comp 280, JMF SMIM & O2, 3" TBE, ECMLink V3, Hallman mbc, 600whp VD / 10.994ET 16. itsmrrizz2you / 12/7/13 / TCOMPtuned / Evo 8 / FP BLACK, Built 2.0, c16, 3380lbs, street tires / 11.48ET 17. sinople1 / 10/1/13 / Strictly Modified Tuned /Evo 9 / BBK FULL, Stock Block, Head, Cams, Full Weight, E85, Supporting Mods / 11.549ET 18. TJO3VIII / 9/21/13 / Evo 8 / FP GREEN, SHEP STG2 TC, HKS 272s, Stock block, intake mani & tb, ported stock exhaust mani, 28psi, 110 oct, street tires, 3200lbs / 11.647ET 19. 90zcrex / 9/6/13 / Self built/tuned / EVO 9 / FP GREEN, Stock block, head & cams / 11.670ET 20. Dsmguy86 / 10/5/13 / English Racing Tuned / Evo 8 / MAP-EF3, Stock Block, S2s, E85, stock trans, Exedy triple, gutted trunk, 18" street tires / 11.671ET List 2 (Evo VIII & IX) - Fastest MPH in the 1/4 - Updated 12/31/13 NAME / Date / Main Sponsor / Evo Type / Setup / MPH 1. Canexican / 11/3/13 / TPG Tuning, FP, CB Racing / Evo 9 / FP ZERO, CB 2.3 ltr, C16, Shep 5spd, Slicks, Weight Watchers / 154.05MPH 2. Flyin_banana / 12/14/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 151.78MPH 3. Stamatis evo6 / 9/16/13 / Extreme Tuners / Evo 6 / ET BB 63mm, Built 2.0L, stock intake mani, exhaust mani, TB & trans, VP Fuel, M&H 235/60/15 tires, 25psi / 148.33MPH 4. AreSTG / 11/16/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.4L, e85, QTP's / 144.69MPH 5. TheKidd113 / 8/24/2013 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, e85, Hoosier DR's / 141.82 MPH 6. 1RedEvo / 2/10/13 / ATP Turbo / Evo8 / ATP GTX3576R, Built 2.0L, E85, stock ecu, QTPs, 37 PSI / 138.44MPH 7. PrimerSdime / 5/22/13 / Evo 8 / FP BLACK, stock block, Kelford 272's, E85, QTP's, stock transmission / 138.27MPH 8. 5LEEPERISAH23I / 6/14/13 / TSComptuned / Evo 9 / FP BLACK, TSC 2.4L, Stock ECU+SD, e85, Street tires, 3345lbs, 630WHP VD / 137.30MPH 9. maknuge / 9/1/13 / MDR Tuned / Evo 9 / FP BLACK, stock block, e85, street tires / 133.59MPH 10. 420a-t / 7/6/13 / Evo 8 / FP BLACK, stock block, comp 280, JMF SMIM & O2, 3" TBE, ECMLink V3, Hallman mbc, 630whp VD / 133.09MPH 11. john ix greece / 6/8/13 / Evo 9 / MAP-EF4, Built 2.0, pump gas+meth, 60ft-1.66 / 132.88MPH 12. raasfaas / 10/13/13 / Speedshop(Jamaica) / Evo 9 / FP RED, Stock Block, S2's, Street Tires / 132.86MPH 13. itsmrrizz2you / 12/7/13 / TCOMPtuned / Evo 8 / FP BLACK, Built 2.0, c16, 3380lbs, street tires / 132.19MPH 14. Gotwheelhop / 1/24/13 / Evo 8 / FP BLACK, 2.3 stroker, English Racing tune, 29psi / 132.11MPH 15. fabcas311 / 2/1/13 / JMS tuned / Evo 8 / FP BLACK, MAP 2.0, stock trans, comp stge 4 clutch, gutted trunk, street tires / 132.00MPH 16. rong / 8/18/13 / Buschur tuned / Evo 8 / FP RED, Buschur 2.3 liter w/ mivec built head, M3 cams, AEM, Hoosier QTP/RX7 rims / 131.64MPH 17. jezzy101 / 8/18/13/ Iveytune / Evo 9 / FP BLACK, 2.4, tuned by Sean Ivey, E85, Hoosier DR's / 129.21MPH 18. Dsmguy86 / 10/5/13 / English Racing Tuned / Evo 8 / MAP-EF3, Stock Block, S2s, E85, stock trans, Exedy triple, gutted trunk, 18" street tires / 127.75MPH 19. sinople1 / 10/1/13 / Strictly Modified Tuned /Evo 9 / BBK FULL, Stock Block, Head, Cams, Full Weight, E85, Supporting Mods / 121.46MPH 20. 90zcrex / 9/6/13 / Self built/tuned / EVO 9 / FP GREEN, Stock block, head & cams / 120.36MPH List 3 (Evo X) - Best E.T. in the 1/4 mile - Updated 11/08/13 NAME / Date / Main Sponsor / Evo Type / Setup / ET 1. BlueX / 4/07/13 / ATP Turbo / Evo X / ATP GTX3582R, pistons, rods, cams, E85, Hoosier DRs, 38 PSI / 10.579ET 2. Mr.Move /10/25/13 / E-Spec / Evo X / Blouch-E-Spec Prototype Turbo, stock block & stock head, 93oct / 11.718ET 3. Hiboost / 6/23/13 / STM / Evo X / TD05H-20G, Stock 2.0, Standard Bolt-ons, Self Tuned, 93 oct, 26 psi / 11.758ET 4. MR:PartyPete / 5/24/13 / Boostin Performance / Evo X / FP RED, Stockblock, 93oct / 12.105ET 5. Joeyhauser / 3/31/13 / Speedcircuit built-Hollywood_x tuned / Evo X / FP RED, built 2.2L, 91 oct, all season-winter tires / 12.245ET List 4 (Evo X) - Best MPH in the 1/4 mile - Updated 11/08/13 NAME / Date / Main Sponsor / Evo Type / Setup / MPH 1. BlueX / 4/07/13 / ATP Turbo / Evo X / ATP GTX3582R, pistons, rods, cams, E85, Hoosier DRs, 38 PSI / 138.35MPH 2. Hiboost / 6/23/13 / STM / Evo X / TD05H-20G, Stock 2.0, Standard Bolt-ons, Self Tuned, 93 oct, 26 psi / 117.09MPH 3. Joeyhauser / 3/31/13 / Speedcircuit built-Hollywood_x tuned / Evo X / FP RED, built 2.2L, 91 oct, all season-winter tires / 115.69MPH 4. Mr.Move /10/25/13 / E-Spec / Evo X / Blouch-E-Spec Prototype Turbo, stock block & stock head, 93oct / 113.94MPH 5. MR:PartyPete / 5/24/13 / Boostin Performance / Evo X / FP RED, Stockblock, 93oct / 107.59MPH List 5 (Ralliart) - Best E.T. in the 1/4 mile - Updated 12/31/13 NAME / Date / Main Sponsor / Setup / ET 1. Rahtid / 12/20/13 / 09 RA / FP RED, Stock block, Jester tune, 27 psi / 12.238ET 2. silthos / 1/27/13 / 09 RA / FP RED, Stock block, Hollywood tune, 27.5 psi / 12.400ET 3. 4. 5. List 6 (Ralliart) - Best MPH in the 1/4 mile - Updated 12/31/13 NAME / Date / Main Sponsor / Setup / MPH 1. silthos / 1/27/13 / 09 RA / FP RED, Stock block, Hollywood tune, 27.5 psi / 114.32MPH 2.Rahtid / 12/20/13 / 09 RA / FP RED, Stock block, Jester tune, 27 psi / 113.55MPH 3. 4. 5. |
Will a MOD/ADMIN please sticky this thread & un-sticky the 2012 list?? Thank you!!!
Also congrats to everyone on the list last year!! Emery @ STM went the quickest with a 9.436ET @ 147.01MPH....This was on STOCK BLOCK TOO!! Flyin_banana went the fastest, trapping 147.964MPH with a 9.742ET Nice job guys!!! Good Luck to everyone this year!! |
Guess I'll toss in here first.
Gotwheelhop / 1-24-13 / Evo 8 / 2.3 stroker, FP BLACK, English Racing tune, 29psi / ET 11.743 w 2.0 60ft. Gotwheelhop / 1-24-13 / Evo 8 / 2.3 stroker, FP BLACK, English Racing tune, 29psi / 132.11mph Slip breakdown - R/T - 1.182 60' - 2.063 330 - 5.394 1/8 - 7.913 MPH- 95.61 1000 - 10.027 1/4 - 11.743 MPH - 132.11 |
Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI / 9.870 ET
Flyin_banana / 1/26/13 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, 26x8.5 MT's, Sheptrans 4.11 FD, 39 PSI /147.003 mph http://i263.photobucket.com/albums/i...ps71c75ccf.jpg |
Last year my best pass was 11.0. 10s this year or bust!
silthos / 1-27-13 / 09 RA / stock block,FP RED, Hollywood tune, 27.5 psi / ET 12.400
silthos / 1-27-13 / 09 RA / stock block,FP RED, Hollywood tune, 27.5 psi / 114.32 MPH I need more practice. http://i359.photobucket.com/albums/o...26F1462F79.jpg |
fabcas311 / 2/1/13 / jms tuned / Evo 8 / map built 2.0,fp black, stock trans. comp stge 4 clutch,(gutted trunk:),street tires / 10.741 @132
Damn a bunch of you guys hit the track already, nice!
Originally Posted by silthos
(Post 10640075)
List updated...:beer:
flyin_banana...when we gonna see some 9.5s?! {thumbup} |
Originally Posted by 06MREvo
(Post 10640246)
Put yourself in the correct format like everyone else has & I'll add you to the list...{thumbup}
Top 2 fastest are LY's for the moment.
Ugh here we go again :( :lol:
