Launch control boost experiences
Tell me about your launch control boost experiences..
How much psi do you suggest me to launch with GT3582R? Just rev limit like stock isn't good choice? With stock turbo I had very good success with just rev limit. My whole engine is stock so I don't want to strees it very much with high boost launch.. |
I usually run very little boost with higher RPM, about 5lbs or so. I usually cut high 1.4 60's. Too much boost I'll just blow the tires loose and hurt the 60'.
I have not tested with lower rpm/more boost yet. |
10.01sec stock block? You are my future :P
Stock turbo with just rev limiter at 6000 around I had boost 5-10psi and I had very good 60' with 17" radials.. 1.6!! Now I will run with 15" slicks (26-8.5-15)! I will try your method! What turbo are you run? How much rpm do you launch it? Tire pressure? |
Originally Posted by GreeceS13
(Post 11451672)
Stock turbo with just rev limiter at 6000 around I had boost 5-10psi and I had very good 60' with 17" radials.. 1.6!! Now I will run with 15" slicks (26-8.5-15)! I will try your method! What turbo are you run? How much rpm do you launch it? Tire pressure? I am on a PTE 6262, 15" Hoosier QTP's, and launch around 6-6400 depending on track conditions. |
