Flash 2005's yet?
Hey Al,
I'm just checking to see if you are flashing the '05 ecu's yet, I just got mine, have the pipes and intake on the way, and will need a flash asap. Thanks in advance |
Its in the works - I am going to be spending some time on this tomorrow
If you have the regular '05 - (not a MR version) - then it would assist me if you could provide me with the exact M number from your ecu. You simply slide out yor glove box door and unbolt the 3 10 mm screws holding the ecu then you can turn it around and read the M number on it. Shoot me a PM or post the number here and we will see if I can help you out right away. Thanks |
I'll check it and send you the numbers.
Thanks |
Thanks |
I have my rachet and 10mm in hand, before I go down are there any tools I need to remove the glove box?
I get my MR this week.. i think we need to experiment with my new car
I have an MR now but cant go w/o the ecu
05 Rs
Here are my numbers:
1860A118 (Large numbers) Small numbers next to it: E6T34893H 4818 Very bottom of back face: 0070 So let me know when you have a flash for the Buschur stage III. Bill |
bump
bump
bump
I will probably have the code by late next week and will then begin a short testing cycle to develop some base maps for the new cars which seem to hold a bit more boost and make a bit more power I will be posting up here about the new '05 Evo flashes |
| All times are GMT -7. The time now is 10:03 AM. |
