Post your E85 Fuel Maps
Old May 14, 2010 | 11:20 PM
oldevodude's Avatar
Originally Posted by tscompusa
if you try copying someone elses fuel map you are going to hurt your motor. I feel I can atleast point you in the right direction and make things much easier for you so im going to do so.
Below is a chopped off end of my fuel map. See how each line has its own number? this is what you want to do. You want to block off each rpm level down the line, but make sure the map still remains smooth overall. If you do this you will be able to dial in your afr with a wideband very easy. Remember to make smooth transitions though on the entire map.
Couldn't help but notice those load cells. Do you hit those hgh load cells?
Old May 15, 2010 | 12:43 PM
tscompusa2's Avatar
still using a maf, so yes i hit between 420-460
NASSER400+
Jan 27, 2012 01:34 AM
tephra
Oct 28, 2011 11:28 AM
Jim in Tucson
E85 / Ethanol
Dec 9, 2009 06:58 PM
evossl
Mar 16, 2009 06:11 PM
smokedmustang
89
Jul 8, 2007 12:20 PM
