iTune's E85 tuning notes: AFR
Since i have not seen any real concrete info on E85 Air/Fuel ratios on this forum, i figured i would throw up what i know so that some of you can make more educated decisions on what AFR you should tune for on E85. I will only discuss E85 AFRs in this thread and will start a thread regarding ignition timing in the near future, as i don't have the time to do it currently.
I have been tuning many years and have a lot of experience tuning all of the exotic race fuels, along with pump gas. This was actually my first attempt at tuning E85(due to just getting it in my area), but before i attempted to tune the "Corn Juice" i did a TON of research on this amazing alternative fuel. Some things about E85 i already knew, but i found there was a lot i didn't. I want to share what i have learned while tuning my own car on E85. Despite E85 having been around for a several years now, there is still a vacuum of info on the fuel and some of the info i found was completely incorrect. Most of your pro tuners out there know that E85 is probably one of the best fuels on the market at any price, but they aren't so quick to give up what they know on the subject. First we're gonna start off with Air/Fuel Ratios and what they mean with reference to E85. E85 has a stoichiometric fuel mixture of roughly 9.78-9.8:1 in E85's purest form (Class 1 85% Ethanol summer blend). As the fuel's Ethanol content goes up the stoich range goes down. For instance, 100% Ethanol's stoich is about 9.0:1. E85 will maintain max brake torque much richer than stoich than gasoline will. But, because of it's excellent detonation threshold(due to lower combustion temps, lower peak cylinder pressures..etc), it can be run much closer to stoich than gasoline safer. E85 reaches max thermal efficiency at about 13% richer than stoich, whereas gasoline is about 16% richer than stoich(with pump gas being even richer). But again, E85 can maintain Max Brake Torque well into the 30% richer than stoich range, unlike gasoline which is limited to about 18% rich of stoich. DISCLAIMER: Just because E85 itself will still make power at super rich AFRs, doesn't mean it's a good idea or even recommened. A whole host of issues come with running super rich AFRs, that you need to be aware of, but i will cover later. Therefore Max Rich Torque of E85 is 7.1:1- 8.5:1 With that being said, here is what i would consider a very safe and conservative fuel tune on E85. *AFR's listed in bold are for widebands o2s that are calibrated for gasoline, AFR's in ( ) are actual E85 AFR: Part Throttle lean (max eco) AFR of 16.5:1(11.0:1) 12.4% leaner than STOICH Part Throttle rich AFR of 14.7:1(9.8:1) Spool up... AFR of 13.5:1(9.00:1) WOT... AFR of 12.1:1(8.06:1) 17.7% richer than STOICH *If you're using a wideband that is calibrated for gasoline(14.7:1) and cannot change the calibration of the wideband, take your gasoline AFR and divide it by 1.5 to get actual e85 AFR or use the wideband in lambda mode. 1 lambda is 9.8:1 Here are some common AFR conversions(Gas AFR on left, e85 on right): 18.0:1=12.000 17.5:1=11.666 17.0:1=11.333 16.5:1=11.000 16.0:1=10.666 15.5:1=10.333 15.0:1=10.000 14.5:1=9.666 14.0:1=9.333 13.5:1=9.000 13.0:1=8.666 12.5:1=8.333 12.0:1=8.000 11.5:1=7.666 11.0:1=7.333 Of course, all engines are different and there is still a lot of trial and error when tuning any setup. Having the ability to measure torque output is a must for tuning both fuel and ignition timing with E85. We are only talking about E85's fuel properties in this thread and not taking into consideration ignition timing, boost pressures, different E85 fuel mixtures..etc. Care must be taken when combining all the aspects of the tune and setup, to assure proper limits and safety. I will start a thread in the near future to discuss ignition timing as well as go into much further detail on E85's inert qualities here in this thread. |
Now that we have that out of the way, let's compare E85 with pump 93 octane.
As you can see, the lean side of max rich torque for E85 is 8.5:1, which is 13% rich of stoich. We know gasoline's max rich torque is about 12.5-13.0:1, but because of pump gas' low detonation threshold, we must run AFR's much richer with forced induction. Therefore, AFR's of 22+% rich of stoich must be used to combat detonation, while running E85 13-15% rich of stoich results in no detonation. Why is this, you ask? Here are the reasons why: 1. Lower EGT's. E85 will typically see EGT's 200c below pump gas at the same relative AFR (for instance 12.5:1 pump, 8.33:1 E85) 2. Octane rating of 105 with class 1 e85(raises detonation threshold) 3. Very high vaporization cooling, much more than gasoline, which lowers mixture temps, thus increasing detonation threshold, along with increasing VE 4. Peak cylinder pressure are lower while maintaining a higher and longer overall cylinder pressure, thus raising detonation threshold and making more power due to increase in crank angle 5. E85 burns much more efficiently than gasoline, 27% more efficient 6. despite lower EGT's, E85 creates more exhaust gas volume, which helps with spool without added EGTs So, we know that E85 has a very high detonation resistance, one thing E85 does not have much tolerance for, is pre-ignition. This is where E85 starts to wander from exotic race fuels. E85 cannot withstand pre-ignition as well as it can detonation. I believe this is due to the fact that it actually burns much faster than gasoline(pump or race fuels), among other things. While it's very tolerant to lean mixtures(detonation), over-advanced ignition timing takes a toll quickly on E85. While E85 will take more ignition timing than pump gas overall, it will not allow a lot of ignition advance at peak VE, but will want more and more advance as RPMs rise, this ending up with much higher peak timing numbers. We'll get into that in the timing thread i will start. |
*reserved**
**reserved**
Good info. Thanks for sharing.
OFF TOPIC: Any links to details on your RSX-S? :mitsu: |
Good to see another person adopting E85. When discussing E85 on EvoM, its become somewhat of a convention to express it in terms of gasoline AFR instead of E85 AFR. There are actually a number of threads/posts in this forum (or on other forums on EvoM) that conclude that ~12:1 gasoline AFR is an optimum value for E85 based on tuning experience. Your notes about E85 being able to run leaner than gasoline are all quite sensible. Here is a challenge for you. Running E85 at a gasoline AFR of richer than about 11.5:1 tends to produce mild knock (as measured from knock sum on the stock ECU) on Evos (don't know about other motors). Would be interesting to see a sensible explanation for this phenomenon.
I run about 11.9-12.3:1 (gasoline AFR). Going richer tends to produce mild knock sums, and going leaner tends to cause break up. I've unintentionally run as lean as about 13.2:1 WOT AFR in the winter. Only issue was breakup. Others have accidentally run as lean as 14-15:1 WOT with no damage. |
Originally Posted by mrfred
(Post 8415463)
Good to see another person adopting E85. When discussing E85 on EvoM, its become someone of a convention to express it in terms of gasoline AFR instead of E85 AFR. There are actually a number of threads/posts in this forum (or on other forums on EvoM) that conclude that ~12:1 gasoline AFR is an optimum value for E85 based on tuning experience. Your notes about E85 being able to run leaner than gasoline are all quite sensible. Here is a challenge for you. Running E85 at a gasoline AFR of richer than about 11.5:1 tends to produce mild knock (as measured from knock sum on the stock ECU) on Evos (don't know about other motors). Would be interesting to see a sensible explanation for this phenomenon.
I run about 11.9-12.3:1 (gasoline AFR). Going richer tends to produce mild knock sums, and going leaner tends to cause break up. I've unintentionally run as lean as about 13.2:1 WOT AFR in the winter. Only issue was breakup. Others have accidentally run as lean as 14-15:1 WOT with no damage. iTune - Great info. Thanks for sharing{thumbup} |
You're absolutly correct. Running richer than 11.5:1 gas AFR does seem to cause knock. I'm not entirely sure why just yet. I dont believe its from the conventional reasons that we experience with gasoline when running too rich(i.e. carbon deposits causing pre-ignition...etc.). This is something im looking into as speak.
I experience light knock at afrs richer than about 11.0:1 with my own car, but the car seems to tolerate really lean mixtures(13.0:1) very well. With the sweet spot being about 12.5:1 gasoline AFRs. I'm running this currently as the engine seems to be really happy here, although i dont think i will run this lean on the final tune. 12.3:1 seems a little safer while still keeping things proper. So, with that said, im amazed at e85's detonation resistance. The knock we're seeing with rich afrs might just coincide with my theory that e85 has a low pre-ignition resistance, despite having a lot more resistance to detonation.
(Post 8415463)
Originally Posted by EvolNinja
(Post 8416098)
mrfred - can you elaborate what you mean by "break up"? I want to run e85 too but I don't want to break my motor.
Originally Posted by iTune
(Post 8416213)
I experience light knock at afrs richer than about 11.0:1 with my own car, but the car seems to tolerate really lean mixtures(13.0:1) very well. With the sweet spot being about 12.5:1 gasoline AFRs. I'm running this currently as the engine seems to be really happy here, although i dont think i will run this lean on the final tune. 12.3:1 seems a little safer while still keeping things proper. So, with that said, im amazed at e85's detonation resistance. The knock we're seeing with rich afrs might just coincide with my theory that e85 has a low pre-ignition resistance, despite having a lot more resistance to detonation. |
Cary, tuned quite a bit today, I have a perfect place BTW... I MEAN PERFECT! Anyway, I really need bigger injectors, 95% duty cycle at 24 psi...static at 25 psi... gonna stay where its at for a while...
Anyway, 16* up top so far and 11.9-12.1 AFR. |
my tune during the day is around 11.0-11.3 and at night its 11.8-12.1 . I dont see any knock with either afr, and not really any extra power gains either.
12.6-12.8 seems to spool the turbo the fastest. I managed to produce 33psi by 3800rpm on an fp black and anything leaner yielded in a few 100 rpm loss in spool. The only thing I dont like so far is how weather changes the tune so drastically with e85. Almost makes me want to make 2 maps for e85 :lol: |
I have noticed this as well... I tuned in 95* heat and then later in the night when it was about 80 and my tune chaged quite a bit...
Originally Posted by Fast_Freddie
(Post 8419933)
maybe bryan @ GST or Aaron will step in and give us their expert advice. I asked Sean Ivey but he didnt get back to me on that specific question. that ussually means its ok tho when he ignores the question :lol: |
12.2-12.4 be carefull that is going a bit on the lean side keep it at 12.0 indicated and sweep the timing.
Sean |
Originally Posted by Sean@Iveytune
(Post 8420044)
Sean |
| All times are GMT -7. The time now is 10:30 AM. |
