Open or Closed Loop on E85?
I've been on E85 since April this year. I'm in open loop at all times to achieve 17.0:1 idle and cruise. I love it and it's been great!
EXCEPT this winter. Cold start, cold idle (dies and rpm fluctuates), bucking when cold, etc problems. I tried doing the things mentioned in cold start/idle threads (it got a little better). I tried messing with the timing. Car drives great when coolant gets to about 100+ degrees. That's about 3 minutes of warming up in the garage. I need a clearer understanding of what's going on here. I'm confused with the ISVC and the Idler stepper tables, so I haven't touched them. Is there a tutorial or can someone shed some light on this? Does this have anything to do with being in open loop? And what IPW should I be at idle? I'm at 2.048. I see people trying to get below 1.28. |
Also, what are you guys doing on E85, open or closed loop?
I run closed loop with E85... but I still let my car warm up before driving the car...
Update:
I've switched to closed loop because I was getting ready to switch over to SD and I wanted to check my fuel trims to make sure they were good. They are. Anyhow, WOW, what a difference! It drives so much smoother. So smooth in fact, I've decided to hold off on SD. As a bonus, I am getting 2-3 mpg better gas mileage. I've gone through 2 tanks of fuel so far, so it's pretty much verified. Thanks Freddie at Spec Ops and Tom at tscomptuned for their input! |
Glad it is doing better!
I recently changed from open (16.5:1 AFR) to closed loop on E85 and saw a 10% MPG improvement after reinstalling the EGR hardware. Mitsu engineers use technology that really works.
I kind of wish there was a way to change the closed loop target afr for e85.
It's funny you would see a beter mpg on the richer closed loop afr then the appropriate open loop afr but I guess I could see how that's possible. I'll be finishing up my tune here soon and I guess I do a few tests of my own. |
Originally Posted by Live4Redline
(Post 10645128)
It's funny you would see a beter mpg on the richer closed loop afr then the appropriate open loop afr but I guess I could see how that's possible. I'll be finishing up my tune here soon and I guess I do a few tests of my own. I think maybe CL is more effecient. IDK. |
Fluctuates due to distance of the sensor away right? Place the wbo2 in the narrow band location for better results ? I'm thinking of doing this right now for 93
Originally Posted by 211ratsbud
(Post 10719531)
