Running E85? Educate yourself with this article!!
Here is a great read for anyone that runs E85! A lot of facts that you may not know, but are detrimental to understand{thumbup}
http://www.injectordynamics.com/AlcoholArticle.html |
At least in CA we don't have to deal with the winter mix. It's "85 percent" all year.
Not running E85 (yet?) but that is certainly a good read with plenty of insight.
Thanks! |
Originally Posted by RJones
(Post 9941701)
Originally Posted by boostless
(Post 9942878)
I'm pretty sure it stays pretty consistent, but is says that norcal switches from a "class 1" to "class 2". So I assume that Socal may be susceptible too. I guess it's most important for your tuner to not tune to the ragged edge.
Great read.
no doubt that anyone running e85 should monitor eth content of their fuel. also good to regularly monitor afr. with that said, i've found through some incidental testing that i can run the same tune for anywhere from 60-72% eth. ymmv on that, so check for yourself. big issue is that its not easy to monitor water content.
Great write up I have always paid very close attention to my injectors and fuel system while running e85 because living here in ny where the weather changes every 5 min you just have to stay on top of things.
Thanks for the info & good write up too.
I know that evom may not be the place for this, but I really don't understand why you guys keep using corn ethanol when it is the most inefficient means of production? Yes, you make power, but at what cost when the prices of gas and e-85 are balancing out? In regards to energy production, corn for ethanol requires 1,150 times as much land as nuclear energy. This statistic may be out of context, considering it is in terms of energy production and not vehicle consumption, but if that much extra land space is being used for energy, how much more is being used for for vehicles? Sorry if this seems like a rant, I'm just playing devil's advocate, and something so unsustainable and inefficient is not going to last...what will you do when e-85 stops being produced?
Originally Posted by PKEVO8
(Post 9947256)
Great read. Good find.
(Post 9947256)
There are many arguments out there for or against this fuel. I think E85 is a good idea for getting off foreign oil when you put it together with Natgas, other bio fuels. Problem is, information warfare makes change extremely difficult. They are so many myths out there, that it makes progressive change come to a stand still. LoL dont get me started on dysfunctional politics too hehe joking... point is. Is it the best fuel out there? probably not. Are there uses for it. Hellz ya :) |
Love the stuff!!! Don't really like the glow in the dark options!! LOL!!
(Post 9947256)
