Check out this build
Not my car.
Mark French in NJ tuned the car, only runs on e85 at the moment. 2.4 4G64 block, Decked & O-ringed 2.1 De-stroker kit Manley TT Crank Manley TT Rods Manley 9.5.1 HD Pistons L-19 ARP Head studs (Gold) Manley springs & retainers Ferrea valves Kelford 280 cams AEM cam gears STM 4port breather/oil catch can bolted to the trans Koyo Half size drag radiator Drivetrain & Turbo Kit Exeddy triple disk clutch HD Built Shep Trans with fresh synchros RS Transfer Case with LSD STM forward facing turbo kit Precision 64/66 ball bearing gen2 turbo AMS intercooler Beanfab custom intercooler piping Tial Q 50mm BOV Tial MVR wastegate 44mm dumps out the hood STM full exhaust all V-band SparkTech CDI coil pack Taylor battery relocation kit to trunk AEM fail safe wideband & boost ECU & Fuel system Speed density setup AEM V1 computer AEM fuel rail AeroMotive FPR ID2200cc injectors Bucshur double pump kit Dual Walbro 450 pumps what do you guys think of this build? Would you consider it a turn key and drive build? according to the owner it is. I might buy it the build has 5k miles on it. I'm going to check the car out today. https://images.craigslist.org/00I0I_...m_1200x900.jpg |
Pictures ?
Went to see the car today, it is extremely fast pulls great. The car only runs on E85 so he cold started it in front of me, car was a little hard i figured E85 and 2200cc injector to start 32 degrees here but once she warmed up it was fine.
E85 cold starts can be remedied in the tune
Wow, big WHP Build. How much $$$ |
Around 20k, the trans felt great it was just rebuilt. about 1500 on trans 4500-5k on motor. If i pull the trigger id take it to the tuner near me, tune it on 93 for much less aggressive tune.
Originally Posted by Aidanlee1
(Post 11852108)
:beer: |
yea weekend car garage kept.
Just be cautious :D Might want to look over it good after a few pulls. See how much the coolant goes up, look for leaks etc. You can tell the car has seen a lot of installs from the diff colors of parts, how much paint is missing around the bay, some rust now etc. Dynojet can’t lie though and it’s making good power! Would be fun on the freeway for sure. |
Yea i am still up in the air about it because the guy told me it will pass emissions, but with the aem v1 i am pretty sure you can't? I live in va the emission sensors have to be "ready". He just had 2k of maintenance on the car including replacing the head gasket he showed me the receipt for that.
