EcuTek'ed... what are my options?
Old May 24, 2006 | 11:51 AM
AutoXer's Avatar
What technically stops the ECUFlash from reading the EcuTek flash? Does the EcuTek flash change the init string? The kernel doesn't have to be loaded to do a read does it?
Old May 24, 2006 | 03:01 PM
MalibuJack's Avatar
I do think it somehow alters the init sequence.. But we'll wait for someone who knows to answer this one.. and no, after the ECU is put into bootstrap mode, it uses its own bootstrap code to extract the Rom.. Therefore any ECU could be recovered from a bad flash.. which is why I find the ECUTek thing odd.. I dont have an issue with it not being editable, but at the least the owner should be able to back it up..
Old May 24, 2006 | 03:22 PM
AutoXer's Avatar
Originally Posted by MalibuJack
...I dont have an issue with it not being editable, but at the least the owner should be able to back it up..
My thoughts exactly.
I just tried to read the EcuTek flash again, just to make sure I didn't do something wrong. Same thing as before.
Portion of the log:
Sending init sequence 1 (0001)
Sending init sequence 2 (FFFF)
No responce from any know code
Old May 26, 2006 | 08:39 AM
chrisw's Avatar
why not try to get the dealer to reflash the ECU? Even the tuner who installed the ECUTek flash should be able to restore the factory ROM image.
Old May 26, 2006 | 03:36 PM
Second Chance's Avatar
Portion of the log:
Well there is only about 4294836225 different combinations of init sequences...
testerix
Jun 20, 2016 05:44 AM
Jonno99
Mar 10, 2016 12:46 PM
PERRIN_Jeff
19
Jul 7, 2008 07:13 PM
Jooyoung99
May 14, 2008 04:55 PM
TurbotrixRacing
Jan 25, 2008 10:23 AM
