Injector scaling and latecy for different injectors.
Old Apr 26, 2009 | 11:25 PM
  #796
bigric09's Avatar
their 1050's most be seriously different than my 850's were. my 850's were scaled at 770 and that worked spot on.
Old Apr 27, 2009 | 03:04 AM
  #797
SEEnoEVO's Avatar
The car is running 13.9-14.0 V.
Old Apr 27, 2009 | 07:26 AM
  #798
mrfred's Avatar
ok, go ahead and raise the scaling by one or two steps.
Old Apr 27, 2009 | 06:15 PM
  #799
SEEnoEVO's Avatar
OK...with the same latencies I scaled to 1170 and ended up with a Mid of -1.95 and a low of -2.5. Now I know this is where I want to be and could probably tweak the latencies a little to get it even closer, but doesnt this scaling seem rediculously high?!?!?
Old Apr 27, 2009 | 08:48 PM
  #800
mrfred's Avatar
Those are good values. I wouldn't touch the latency. Did you go one or two steps higher in injector scaling? If you went two steps, you could try backing off one step, but I suspect it will put you at ~3 for idle and cruise trims. Don't worry about the high scaling value. It just means that these injectors are quite a bit larger than the advertised value.
Old Apr 28, 2009 | 04:25 AM
  #801
SEEnoEVO's Avatar
This is two steps higher. I tried only one step higher and it still wasnt good. I dont understand how they are quite a bit larger than advertised. The flow sheet had 3 @ 1072 and 1 at 1080. I will watch my AFR's and tune accordingly, but was just worried about the high scaling. I have read posts by other members that state that you shouldnt be scaling that high for 1050's and that by doing so will cause lean issues up top.
Anyone else have an opinion? Should I scrap this scaling and start back over lower and mess with latencies and MAF scaling? I have been doing this for weeks now. I am half way tempted to just pay someone to get it nailed down for me. Any takers??
Old Apr 28, 2009 | 07:25 AM
  #802
SEEnoEVO's Avatar
Oh yea and one other thing. The idle trim was obviously just that...a 20 minute idle trim average, but the cruise trim went from -1.7 to -2.3 and settled at -1.95 while doing a constant speed 20 minute cruise. Once I got off the expressway, the and did normal driving, the cruise trim shot to -9. Is this normal? I would guess the constant speed trim is most important but I was just wondering.
Old Apr 28, 2009 | 09:12 AM
  #803
mplspilot's Avatar
SEEnoEVO,
If you see 7's or 8's in your fuel maps for WOT with the current scaling, i would bring it down to the number that you feel comfortable with and where you see 9's or higher in the WOT fuel map. Then lower your latencies to bring mid trim closer to 0. Then use MAF scaling to bring low trim closer to zero.
You have an aftermarket intake on the car that is affecting MAF readouts, so i wouldn't recommend wasting weeks of your time hunting for perfect +/-1 trims. If they are within 5-7 or so and you have no driveability issues, leave them alone. That's what they are there for, to adjust your fuel, so that you dont have to rescale injectors for each different batch of fuel. Obviously it doesnt hurt to check that you don't have any boost/vac leaks.
Old Apr 28, 2009 | 10:02 AM
  #804
SEEnoEVO's Avatar
Originally Posted by mplspilot
SEEnoEVO,
Thanks man I appreciate the tips. Go figure my Innovative WB had to start screwing up while I was finally getting my trims in a good range so I need to figure that out now. I will be watching my AFRs very close and if it does seem that I am having to dump a ton of fuel to get to my mid 11's at WOT, i will look at rescaling them. Thanks again for all the help guys.
Old Apr 28, 2009 | 12:31 PM
  #805
SEEnoEVO's Avatar
Since everyone has been so helpful, I did notice that at this scaling, when coming to a stop, my RPMs rise by about 400 before coming back down to normal about 3 seconds later. Any ideas on this?
Old Apr 28, 2009 | 04:40 PM
  #806
EvoPlaya31's Avatar
Originally Posted by merlin.oz
Here is a set of three that should be good, all the owner/tuners report good results.
From fostyou:
Scaling=680
4.7V = 3.642
7.0V = 1.992
9.4V = 1.344
11.7V = 0.984
14.0V = 0.744
16.4V = 0.576
18.6V = 0.456
From joedr:
Scaling=713
4.7V = 3.504
7.0V = 2.184
9.4V = 1.224
11.7V = 0.960
14.0V = 0.792
16.4V = 0.552
18.6V = 0.432
From cpoevo:
Scaling=696
4.7V = 3.504
7.0V = 1.872
9.4V = 1.224
11.7V = 0.960
14.0V = 0.774
16.4V = 0.552
18.6V = 0.432
As you can see, not much variation.
If it was me, I'd use cpoevo's settings and see what happens.
i just tryed the 713, with my 780 and it works great for now. what size injectors did he have??
Old May 21, 2009 | 09:26 AM
  #807
Fast_Freddie's Avatar
Veteran: Navy
I have noticed this too... I have FIC 750s and the 0011 rom and mine does the same thing... a good thing if you are VTA to avoid the stalling issue! However it doesn't do this with the 006 rom... weird...
Old May 21, 2009 | 03:57 PM
  #808
ExViTermini's Avatar
Friend of mine is running stock, read: stock, injectors, and is throwing 0172's and trims are very negative.
Only thing I can guess is the ETS intake pipe(it idles at like 50-55hz...adjusting mid trim only of course). Would it be odd to scale the maf down, instead of up?
Old May 26, 2009 | 06:15 PM
  #809
sub7's Avatar
Can we trust FIC latency data (eg: 850cc and 1050cc been told are same)? They sent me sheet of info and I think opening response is what we interested. Measurement given at 43.5psi (fuel pressure if I'm not mistaken).
Opening response (ms)
10v - 1.38
12v - 1.13
14v - 0.97
16v - 0.88
Closing response (ms)
10v - 0.99
12v - 1.00
14v - 1.01
16v - 1.02
As oppose with another injector lag time, they are completely different:
10v - 1.02
11v - 0.87
12v - 0.74
13v - 0.62
14v - 0.51
15v - 0.43
Old May 28, 2009 | 04:54 AM
  #810
E85evo8's Avatar
does anyone know or is using FIC 1450cc inj and have inj. latencies that I can compare with mine?
