Evoscan Log Analyzer 2.0 with Load!
Old Sep 1, 2006 | 11:21 AM
  #31
MalibuJack's Avatar
Originally Posted by Wallesasuaz
it's the EVOscan. I try unpacking it and it won't unpack along w/ everything else. When I try and run it from the zip folder it says it's harmful and my system won't allow installation. whatever.
So scanning it might help you think? The only protection on my computer is XP crap.
YOu might want to install a copy of Winzip instead.. XP and its built in "Zip Folder" feature doesn't seem to work very well, your better off extracting the files using winzip and running it from there.
I have to be honest with you, I've tried this on every machine I have here, including an updated and current Generic base XP install that I use for testing in VMWare, and none of them generates the error your describing.
Old Sep 1, 2006 | 11:22 AM
  #32
MalibuJack's Avatar
Originally Posted by chmodlf
Yea dude you are breaking the EvoM map/log vendor posting rules
BTW thanks for all of your hard work AND sharing. We appreciate it.
Well, Considering I'm the Tuner, Owner, and Distributor of the logs and map, I doubt I'll sue myself for damages.. I may just slap myself around a little, but I'm sure I can take myself in a fight..
Old Sep 1, 2006 | 11:32 AM
  #33
Wallesasuaz's Avatar
Thank Jack. I was probably not explaining it so well since it's not in front of me and I'm stuck at the office right now.
But i'll give that a shot and get back to you dude.
Thanks!
Old Sep 1, 2006 | 11:39 AM
  #34
Evo_Jay's Avatar
Malibu, In one of your screen shots, it looks like your using the ECU+ program to look at the logs, is this correct?
Old Sep 1, 2006 | 11:41 AM
  #35
evo 8 ya's Avatar
Originally Posted by C6C6CH3vo
So I need to upgrade my 1.1 net framework to 2.0 first?
That's what worked for me.
.NET Framework 2.0 Download
Old Sep 1, 2006 | 01:20 PM
  #36
RazorLab's Avatar
Very nice MalibuJack!
Can't wait to try it out. If you are ever in Northern California, I owe you a beer or 10...
Old Sep 1, 2006 | 01:21 PM
  #37
RazorLab's Avatar
No I think he is logging via ECU+ as well. I don't think you can view other logs in ECU+.
Old Sep 1, 2006 | 01:33 PM
  #38
justchil's Avatar
Wow this is cool. I've hit a peak load of 315ish and am over 300 a good bit. I couldnt really get any great logs because even 3rd gear on wet cool roads I start spinning
Old Sep 1, 2006 | 01:37 PM
  #39
992gnt's Avatar
What are your load axis rescaled to? I'm curious to see if it shows load values over what is defined in the maps. I can't wait to get home and try it out, nice work Jack.
Old Sep 1, 2006 | 01:52 PM
  #40
justchil's Avatar
300 right now. Looks like I may need to go up to about 320 or possibly even high as I run 3psi more at the track.
I'm hitting right below/over 300 pretty often in this log. The highest spike was 2nd gear but the car was spinning like crazy.
Data Log Lab is awesome! This is really eye opening for me... with the purchase of a 24" ws monitor and DLL.. well I'm stoked to say the least
Old Sep 1, 2006 | 03:00 PM
  #41
MalibuJack's Avatar
I'm glad you guys are enjoying the little widget..
Old Sep 1, 2006 | 03:41 PM
  #42
inco9nito99's Avatar
Amazing work my friend...thanks a lot! The grahical data is nice! Reminds me of DSMLink.
Old Sep 1, 2006 | 04:24 PM
  #43
sesso's Avatar
JACK how did u get the values to match in datalog lab?
Old Sep 1, 2006 | 04:55 PM
  #44
992gnt's Avatar
Interesting. I'll be more than a little surprised if I surpass 300, but it's good know that there is a way to tell now where exactly you need to rescale to.
I've been using DLL for a couple years now, I originally got it to view my emanage maps. It's a great little tool.
Old Sep 1, 2006 | 06:36 PM
  #45
Kyle_Y's Avatar
Yo MJ (geez sounds like Spiderman2 character )
Thanks for the work .. very close to spot on for my logs .. seems fair to say about 1 degree retard for every 3 knocksum encountered
Now to figure out why my load drops from 280 to around 230 at 7000+rpms
and this boosting at 26psi ..sigh .. beginning to suspect the 3071 is a bottleneck with a 0.63 AR hotside ..
