EVO 9 Open Loop Throttle Low and High?
Old Apr 2, 2007 | 01:38 AM
tephra's Avatar
60.4%@500rpm tapering to 34.1%@7500rpm?
does that sound better?
Old Apr 3, 2007 | 01:12 PM
C6C6CH3vo's Avatar
I changed mine in accordance to the fuel map stoich values - basically changed the load to the value that isn't stoich on the AFR map - thats what the stock ROM does.
I did however lower the throttle value significantly on spool RPM to properly synch it to whats going on - my setup builds boost at mild throttle input compared to stock.
This area of transition is the toughest for me to tune and understand - I also get knock in closed loop, part throttle and less than 5 psi conditions - headache
lancerrally45
Jun 15, 2016 12:25 PM
5LEEPERISAH23I
Mar 7, 2016 12:04 PM
1 WICKED EVO
Sep 8, 2007 12:31 PM
Mad_SB
Jul 13, 2006 05:18 PM
04T-WRX
Lancer Engine Management / Tuning Forums
Mar 1, 2006 04:43 PM
