? About EcuFlash and OBD 2 Generic Scan Tool
Old Nov 9, 2006 | 11:49 AM
EvoAnthony's Avatar
Ok so I got the cable and I got the EcuFlash and the newest OBD 2 Generic Scan Tool that MalibuJack posted a short while ago. I opened the Scan Tool and I cannot figure out how to have the EcuFlash and the Scan tool open at the same time because the Scan Tool cannot be minimized, just closed. Please help me MalibuJack!!!
Thanks,
Anthony
Old Nov 9, 2006 | 01:01 PM
dryad001's Avatar
Why do you need both open at the same time?
If you want both programs to run at the same time using the cable you wont be able to.
Old Nov 9, 2006 | 01:05 PM
EvoAnthony's Avatar
Well then how do you see knock and other things when tuning on the dyno??
Old Nov 9, 2006 | 01:18 PM
dryad001's Avatar
Certainly not with that OBD scanner.
Here's what you do.
Go to aktivematrix.com
become a member
download MalibuJack's Mitsulogger
and BAM you can log everything your heart desires.
Old Nov 9, 2006 | 01:28 PM
EvoAnthony's Avatar
You must be confused...I have the logger. Heres what I have: http://www.techdiag.co.uk/obdscantech/web/Download.htm
Old Nov 9, 2006 | 01:38 PM
MalibuJack's Avatar
the OBD-II Logger is not the best tool for logging anything, its too slow, but it works for generic stuff, and reading/resetting the MIL codes..
You need to run something like Mitsulogger if you want to log data using the native MUT protocol..
OBD-II Scantech maximizes itself, its the only real glitch with the program, but its actually not a glitch, it was intended to work with an in-car PC..
For logging, use MitsuLogger or EvoScan.. for CEL Codes and checking if your car will pass an inspection, use OBD II Scantech, and for reflashing, use ECUFlash.. OBDScantech is of limited value for logging as OBD-II protocol itself is too slow to do any real tuning.
Old Nov 9, 2006 | 01:39 PM
MalibuJack's Avatar
Mitsulogger was designed specifically to run fast, and use the native Mitsubishi MUT logging protocol which is capable of showing knock, fuel trims, timing, etc.. all the things you need..
Old Nov 9, 2006 | 01:41 PM
wrcwannabe's Avatar
The OBD2 scan tool is for resetting codes and finding out what is wrong with your car. It cannot be ran simultaneously with Ecuflash or Mitsulogger.
You sound like you want to get some data from upcoming dyno runs. You will need to log the car using mitsulogger during the dyno run. It is best to use Mitsulogger along with a wideband o2 sensor. Then open up the log file in Excel or in Dataloglab and check for knock counts and look at the AFR from the wideband.
You can then close out of Mitsulogger and open up Ecuflash, read the ROM from the car, make any changes desired and flash it back to the car using Ecuflash.
Run another pull and check changes using mitsulogger.
Is that helpful?
milburn
Old Nov 9, 2006 | 01:42 PM
MalibuJack's Avatar
Oh and I do keep ECUFlash, Mitsulogger, the ECU+ logger all open at the same time.. I log using Mitsulogger and ECU+ (I have an ECU+ Piggyback).
Old Nov 9, 2006 | 01:51 PM
EvoAnthony's Avatar
Thanks for all the great info MalibuJack!!!!!! You are the best when it comes to this kinda stuff!!!!!!!!!!!!!!!!!!!!!!!!!
lolazour
Oct 9, 2016 03:53 PM
FASTER345
Feb 18, 2015 08:08 AM
Ed Wolfram
May 20, 2007 09:47 AM
tribe
Jan 10, 2007 01:59 PM
MalibuJack
Nov 9, 2006 08:10 AM
