NLTS possible with ECUFlash and stock ECU?
Old Nov 22, 2006 | 04:54 PM
confusionisbad's Avatar
I was wondering if it is possible to get this working with a stock ecu and ecuflash? I had it on my DSM when I had it. If it is possible, what all needs to be done. I currently have an eflash from Jestr Tuning. I searched, but nothing really came up that had good answers.
Eddy
Old Nov 22, 2006 | 04:57 PM
silex's Avatar
That would rock, but searching through ecuflash there's no option for it... yet.
Old Nov 22, 2006 | 05:02 PM
I saw a thread while searching, That Warrtalon has it working with his flash from Al - Dynoflash, but no details on it.
Old Nov 22, 2006 | 05:13 PM
05WhiteEVO8's Avatar
I just keep my foot on the gas while shifting and have never had any issues.
Old Nov 22, 2006 | 06:34 PM
dudical26's Avatar
yea I NLTS with stock ECU no problem.
Old Nov 22, 2006 | 06:39 PM
tobz's Avatar
NLTS? No lift ? Shift. Whats it mean?
Help me out
Old Nov 23, 2006 | 12:21 AM
NLTS = No lift to shift, When I Had my dsm and had dsmlink in it. I was able to have the stationary studder box, as normal. Which was based on speed. Then there was the NLTS which was when you were going or what not, you just keep your car floorer, when the clutch is pressed in the rpm's drop to a set parameter, like 6k rpms. The NLTS used a clutch cut wire that went to the ecu and clutch switch.
How do you have yours working dudical? Does it work as I described above?
Old Nov 23, 2006 | 01:00 AM
voidhawk's Avatar
doesn't the ECU have a two step rev limiter (one clutch in and one clutch out)? I don't remember if the parameter is changed based on the clutch switch or based on vehicle speed (stationary vs. moving), but if it's based on clutch sensor all you'd have to do is change the "clutch in" limit to what you want your NLTS rpm to be, and that should do it?
Old Nov 23, 2006 | 07:07 AM
dan l's Avatar
I don't have time but this is something I wanted to do. Maybe I'll get to it sometime in janurary or feb when I do have more time. I'm trying to build my eclipse for next year and that is taking all my free money and time. Basically just look at the code around the stock clutch in launch rpm. You basically have to rewrite some things using the opcode sheets for the evo processor. Its SH2 as I believe. What we did on DSM's is feed an extra input to the ecu for the clutch in rpm. So:
IF clutch in go to next line
IF RPM above value jump to next line
IF car moving jump to rev limiter code
Then the stock code for the rev limiter is then run until the engine speed drops below the valuey you set. Their are a few different ways to do it. Go to the DSMECU board on yahoo groups and search the archives for how the dsm's do it. I also posted how I do it on this board.
Old Nov 27, 2006 | 02:33 PM
I guess no one has done it yet except Al @ dynoflash.
Old Nov 27, 2006 | 03:16 PM
Ultimate CC's Avatar
Someone has had to do it besides Al and if not maybe Al can shed some light on this...
Old Nov 27, 2006 | 03:41 PM
AlwaysinBoost's Avatar
DynoFlash Al doesn't have any NLTS option... I made a thread about 6 months ago asking if there was a NLTS feature available with his flashes. One person said they actually had this feature installed on their car but more questions revealed this was not true.
I'm sure eventually ECUFlash will have these capabilities and more, its just a matter of time.
Old Nov 27, 2006 | 03:44 PM
I only pickup 1/10th at most when flat-shifting compared to full lift shifting. Most times with a no-lift shift I get false knock which reduce timing and actually slows me down more then if I would have lifted in the first place. So I don't do it anymore... just learn to shift faster.
Old Nov 28, 2006 | 06:06 AM
MalibuJack's Avatar
I've always run my best times by without using any sort of NTLS... Launch control is really the only thing I've used consistently and I don't even set it much higher than what its set stock...
bees_knees84
Apr 23, 2011 03:25 PM
Spy007
Apr 6, 2009 02:36 PM
ITP
Aug 12, 2008 02:51 PM
AutoXer
May 26, 2006 03:36 PM
mchuang
May 22, 2006 02:19 PM
