ECUFlash / Evoscan / Mitsulogger Questions
Old Jan 2, 2012 | 04:18 PM
  #1156
Sirnixalot's Avatar
That's weird. It works fine with Evoscan but not with ECUflash.
Old Jan 2, 2012 | 04:23 PM
  #1157
AndyCT9W's Avatar
The license is something to do with the cable flashing/reflashing will need to be done with evoscan.
Originally Posted by philr8
1.3R cant be used to flash with Ecuflash!!! It doesnt contain the Ecuflash licence.
You must use Evoscan to reflash with the 1.3R
It clearly says this in the product info!!!
"This cable is really an OpenPort 1.3U cable but without the $40 license it costs to use EcuFlash. You can use this cable for full datalogging capabilities, but it has one more advantage than EvoScan 1.3D cable, and that is that you can use this cable with EvoScan v2.7 or EvoScan v2.8 for Reflashing Evo7, 8, or 9."
Old Jan 6, 2012 | 12:23 PM
  #1158
djchopps0013's Avatar
I have searched around a bit but havent found answer I am looking for. I have 2005 Evo 8 MR and 1.3 cable and EvoScan 2.8. I cant get it to scan DTC codes. I get following error:
Info: CPU Timer Factor Applied: 0
Info: Initialization Complete...
Info: OBDII Sync Byte Received.
Info: Keybyte Response: 0x08 0x08
Info: OBDII Keyword CRC Received.
Info: Waiting for vehicle ecu...
Info: Arithmetic operation resulted in an overflow.
Info: Check DTCs Complete.
Any advice would be great.
Old Jan 6, 2012 | 05:49 PM
  #1159
Macaroni's Avatar
Originally Posted by Macaroni
After switching to v7 my logs go crazy. Everything jumps all over the place and nothing is an accurate reading... Here's a sample of what it does at idle...
I've tried searching but came up with nothing.
bump?
Old Jan 6, 2012 | 05:50 PM
  #1160
Macaroni's Avatar
I get the same thing. Mine always says "No response from vehicle ECU". +1 for any advice on fixing this
Old Jan 7, 2012 | 07:11 AM
  #1161
I sent request into helpdesk at EvoScan, not sure how prompt they are but given the lack of info or people experiencing same issue I didnt have any other choice. Was throwing P0138 after wideband install and couldnt get the douchers at autozone to reset, but at least they were able to read SES code. Just pulled battery cable and flashed O2 Heater patch. Well see, but all in all this is a great functionality that isnt working for me.
Old Jan 7, 2012 | 07:17 AM
  #1162
Macaroni's Avatar
I had that code for the longest time until I finally got v7 and now I can't even log the car. Fix one problem get 2 more
Old Jan 7, 2012 | 08:04 AM
  #1163
evoscan's Avatar
Silver Sponsor
it might not be a real problem. you might have forgot that Tephrav7 is 62500 baudrate.
Old Jan 7, 2012 | 10:19 AM
  #1164
Macaroni's Avatar
I'm on the 62500 baudrate and it's still acting up
Old Jan 10, 2012 | 10:24 AM
  #1165
piQuet's Avatar
ecuflash quastion
i downloaded hex from my ecu..what to do now? i cant see any maps, just rom info. I changed user level to developer and nothing change. do anyone got any links, tutorials or something? i just wonna play with those ecu and larn omething new. give me some clues guys please, where to go
Old Jan 10, 2012 | 05:12 PM
  #1166
http://www.youtube.com/view_play_lis...F5C03E946&hd=1
I would start here.
Old Jan 23, 2012 | 09:10 AM
  #1167
Daluv's Avatar
Hi,
I am new to the mitsu world and I am looking for documentation or source on the MUT protocol. There is a SSM.pdf document floating around for the subaru protocol. Is there an equivalent for the mitsu? I would to port my SSM hardware/software to MUT.
thanx
Mart
Old Jan 28, 2012 | 12:36 AM
  #1168
HaVoC187's Avatar
I have been trying to get my UEGO to log for 2 months now but it just won't work and it seems that people are having great succes with version 2.5
Could someone please send me a copy of evoscan 2.5? I would greatly appreciate it.
Old Jan 29, 2012 | 02:01 AM
  #1169
evoscan's Avatar
Silver Sponsor
UeGO works with EvoScan v2.9 use that.
Also EvoScan v2.5 is available for download on this webpage: http://www.evoscan.com/evoscan-updates
Old Jan 29, 2012 | 02:53 PM
  #1170
mrfred's Avatar
Hamish,
I found a few errors in the MUTII EFI definitions:
- You have two coolant temp listings. The definition for the first one listed at MUT07 is wrong. The item you have listed as Coolant Temp Scaled at MUT10 is correct.
- Same situation for Air Temperature. The one at MUT3A is wrong and can be deleted. The one at MUT11 is correct.
- There is an item called "Airflow/Rev" at MUT1D. Its actually baro and airtemp-compensated 1-byte load (the ECU 1-byte load and not tephra's 1-byte load). Suggest renaming or deleting.
- There is an item called "Knock Sum 3E" that reads MUT3E. MUT3E is actually fuel level.
- There is an item called "Load Calculated" that estimates load based on IPW. I think it can be safely be deleted forever.
- There is an item called "Load11bit4". This is airtemp-compensated 1-byte ECU load. Probably a good idea to rename or delete.
- The item called "ECULoad" is uncompensated 1-byte ECU load. Probably can group all the 1-byte ECU loads together if you are going to keep them.
- There is an item called "EGR Temperature" that reads MUT12. MUT12 is actually an airtemp value that's not useful for anything. Would be good to delete this one.
- "Crank Signal", "Idle Position Switch", "Power Steering Switch", "Air Conditioning Switch", and "Inhibitor Switch" all read MUT4A. MUT4A is actually evap purge solenoid duty, so those items can be deleted unless you know the correct MUT address.
