880's with reflash???????
Old Jan 10, 2007 | 10:01 AM
T67Evo's Avatar
Anyone running 880's with reflash???????
Old Jan 10, 2007 | 10:03 AM
WrX Kila's Avatar
No.... But I am running 850's with a reflash. (LOL)
Old Jan 10, 2007 | 10:04 AM
T67Evo's Avatar
When I say 880's Im talking about injectors.......... for those wondering...lol
Old Jan 10, 2007 | 10:05 AM
T67Evo's Avatar
how many lbs of boost are you running?
Old Jan 10, 2007 | 10:06 AM
T67Evo's Avatar
More importantly, how many lbs of boost can I run safely on pump gas with 880's and a reflash?
Old Jan 10, 2007 | 10:08 AM
WrX Kila's Avatar
28lbs-31lbs pump 100% meth!
T67Evo's Avatar
Damn, I don't have meth inj......... how many lbs can I run without meth or alky?
Old Jan 10, 2007 | 10:16 AM
T67Evo's Avatar
What kind of gas mileage are you getting by the way???
Old Jan 10, 2007 | 10:19 AM
LimPShoT's Avatar
I am running 880's ,GT35R turbo with reflash i get about 220 miles to a tank if i am not getting on that much.
Old Jan 12, 2007 | 06:14 AM
Mad_SB's Avatar
dude,
I don't think the size injector is going to determine the max safe boost you can run unless you have an upgraded turbo. If the injectors are scaled properly you should not see any change in your milage and your duty cycles will go down, allowing more headroom for mods before running out of fueling.
The question is not how much boost you can run with x injector, it is do you have enough fueling to support the engines demands for fuel with whatever combination of mods you have.
Old Jan 12, 2007 | 07:31 AM
20psiMR's Avatar
^ +1 ^
Octane determines how much boost you can run, unless you want to just dump fuel into the cylinders to push more boost. That ruins gas mileage AND performance. Run a safe psi on pump gas and crank it up when running race gas. Pump is teh sUck.
Old Jan 13, 2007 | 12:49 AM
EvOcHaRgeR's Avatar
I have 880s with 35R with cams and a flash but I only run 22lbs on 93 pump gas.
Old Jan 13, 2007 | 10:00 AM
G20's Avatar
G20
I have 880s with 35r as well and run 22lbs of boost on 91 and 32 on c16. I used to have 780s but maxed them out at the track (according to evoscan) so upgraded.
Old Jan 14, 2007 | 12:17 PM
Ev0cRaZy's Avatar
I run 880s with GT37r with a Flash.......
Old Jan 14, 2007 | 12:22 PM
T67Evo's Avatar
So what kind of numbers are you guys putting down to the wheels???
