Evo anti-lag ECU disassembly
Old Apr 6, 2011 | 02:45 PM
  #601
211Ratsbud's Avatar
Originally Posted by 211ratsbud
Can someone measure the exact depth of an oe als manifold injection ports?(from banjo bolt side ) I have a spare one to drill but un sure how deep to have them drilled. And does the port holes go between all four cylinders or just one cylinder per tube? If it were the former does this cause any negative effects on the twin scroll ?
anyone?
Old Apr 6, 2011 | 04:05 PM
  #602
Maikumaru's Avatar
anyone?
If you are going through with the drilling (keeping in mind older manifolds etc have the holes already drilled or you could always source one from UK...which is not cheap)
I would have to remove all the hardware to find out... unfortunately not going to happen.
two banjo holes, each have two holes drilled into them from the side. for a total of four.
If you are going to drill, you are not limited by the stock sas piping and could make it however you wish...
how you drill the almost horizontal holes into the larger banjo bolt holes would be a real challenge. I originally thought the same as you, but when I was inspecting the manifold, I was very happy it was not even attempted.
Old Apr 6, 2011 | 05:10 PM
  #603
evoRS06's Avatar
I have posted in this thread and others that as sone as someone that can make me the table that I want to fine tune my anti lag I will post up a how too. I have working anti lag now, but I would like to refine it. I am using a usdm 9 ecu on a usdm 9 with sas valve and lines, everything else is factory usdm. Like I sad, anti lag can be done, but my request for the table has, I guess, been ignored or considered not a priority. So I will wait patiently
Old Apr 8, 2011 | 11:59 AM
  #604
211Ratsbud's Avatar
Ok, I did not notice this. Well, as soon as that happens I am in.
Old Apr 22, 2011 | 05:10 AM
  #605
VGergo's Avatar
Hello !
It is working in the Eu Evo 9 RS ( factory equipped sas sytem ) with 88580714 V7, the ecu didnt cut the fuel when lift off the throttle. max timing retard was -20 degree.
Bajno in the Sas was stock yet . The main thing it is working from the Ecu.
Old Apr 22, 2011 | 05:44 AM
  #606
donner's Avatar
Originally Posted by VGergo
Hello !
Yes, it's also my experiment that fuel is not cut when lift off with 88580014
Did you check if SAS valve was opened or solenoid operating? You can check solenoid operation with Evoscan by inserting command CB (Start datalogger, set custom request to CB or 0xCB, I don't remember...). Anyway with this request, solenoid should "click".
Old Apr 22, 2011 | 06:33 AM
  #607
Danieln's Avatar
Hello !
Can you please post your setup for ALS?
No other modification in timing maps?
Old Apr 23, 2011 | 08:26 AM
  #608
VGergo's Avatar
The settings is nothing special. At all it isn't popping bigger or harder with the working ALS function yet as did an other EU Evo 9 no sas and als code, -20 degree timing only when you lift off the throttle ! What I like is adding fuel... Now need air thru the sas bigger bajnos and or bigger lines, or maybe with a throttle kicker or air bypass valve.
I didnt test the solenoid but I will !
If I set lower value than -20 in the timing retard limit 1 and 2 table than the Ecu will not pull down the timing... So max retard is -20 .
In the Ecu and the rom what control the maximum timing retard limit ? If we know the right code of the table ? Why can't retard more ? Where is the differences between the Evo 6 tme rom -27.5 degree, Evo 9 -20 degree, Evo 8 with v7 9653 -10 is maximum what I can set...
Here is the settings : http://img534.imageshack.us/img534/6132/sasm.png
Old Apr 23, 2011 | 08:50 AM
  #609
211Ratsbud's Avatar
willl somone take a look at what table evors is looking for? puh puh puh pleeeaasee
Old Jun 20, 2011 | 12:51 PM
  #610
Tony.O's Avatar
i installed a new manifold on my EVO VIII USDM that has the tube shown in the above picture + solenoid valve + small vacuum tank, what comes next to make ALS work ?
NB: my rom is 94170715 can i change it to 96531706 ?
i did the patch for max retard limit.
Old Jul 31, 2011 | 04:43 PM
  #611
211Ratsbud's Avatar
You need to wire the solenoid to the ecu. that controls vacuum to the air.valve.
Old Aug 23, 2011 | 12:34 PM
  #612
211Ratsbud's Avatar
badadump up up, anyone make any progress?
Old Oct 6, 2011 | 05:02 PM
  #613
Maikumaru's Avatar
depending on sound setup...easy to hear...and feel
http://www.youtube.com/watch?v=63B5yc4uH8k
Old Oct 7, 2011 | 06:07 AM
  #614
pug206's Avatar
A video I found on youtube
http://www.youtube.com/watch?v=htzcj...layer_embedded
Old Oct 13, 2011 | 10:17 PM
  #615
tme65's Avatar
Hi Guys, I have a JDM TME 6.5. 27370001 ROM I have been trying to get the ALS System and stationary rev limit to work but no luck. I can get it to backfire slightly with the low load retarded ignition but thats not using the SAS.
I am wondering what else I need to set.
Currently I have setup the usual ALS settings.
Air injection time 0.0 0.3 0.6 1.1 1.3 1.3 1.3 1.3 0.9
Fuel injection time 4.8s
ALS Min load to trigger 80
ALS load below which active 45
ALS min coolant temp 50c
usual other settings
I have no BOV atm as it was an atmo
should I try increasing my Fuel injection time to 10s instead of 4.8 and upping the 2D air injection table? maybe upping the ALS min load below which active?
Also I have seen mention of diabling the EGR valve...do I need to do this..no sure if there is even one on a TME
Thanks in Advance
Matt
