HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
Old Jun 7, 2011 | 09:10 PM
  #481
dparrish's Avatar
Originally Posted by razorlab
Evo 8/9/10/RA all run 100% WGDC from the factory, I've tuned hundreds of cars at 100% WGDC up top with no issues and even my personal Evo has run 100% WGDC for going on 6 years now with no engine failures or turbo failures.
I think the problem here is that 100% with either changed restrictor pills or an aftermarket BCS, and the boost correction tables zeroed out, then it can cause overboost. It has nothing to say "that's enough, stop increasing boost now".
Old Jun 7, 2011 | 09:12 PM
  #482
tscompusa2's Avatar
Please stop with your "100% WGDC" misinformed warpath.
So please see how your warpath is misleading. Share proper information.
want to elaborate? he said he had zero'ed out the boost error correction tables therefor the wastegate duty cycle at 100% represents 100% boost pressure..
if not then please explain
if there is no boost pill inline on the vacuum lines and no restriction then how can you run 100% wgdc with boost error correction tables all set to 0?
Old Jun 7, 2011 | 09:13 PM
  #483
RazorLab's Avatar
Yea it's not the tirade he is on currently though.
Back to your original problem. Which ports did you connect to which?
Should be like this with *straight* vac lines:
Also try swapping the plug as you might be using the secondary BCS plug accidently (I'm not sure which one is correct on Evo 7). Of course also bring your WGDC down while testing.
Old Jun 7, 2011 | 09:17 PM
  #484
RazorLab's Avatar
Because that is how 3 ports work. They need no boost pills. The solenoid will run the base WGDC you have in your tables if you have Error Correction zeroed out. If you have 100% WGDC inputted, you get 100% WGDC.
If he has the incorrect port into the solenoid then it's not powered and not running any WGDC.
Old Jun 7, 2011 | 09:22 PM
  #485
tscompusa2's Avatar
ok and i said what wrong then? i know if the BEC is zero'ed out it runs off what is put in the Main Map Wastegate Duty when everything is connected properly.
All I said to him was, he better change the 100% WGDC before he hooks it up right and boosts again or its going to try to run lots of boost.
so im confused did you read what i said wrong or what?
Old Jun 7, 2011 | 09:30 PM
  #486
dparrish's Avatar
Those are the ports that I used (I went off this diagram in fact). I'll have to file off some of the plug on the harness I got from spoolinup to make it fit in the other BCS socket but I'll do that tonight if replacing all the hoses doesn't fix the problem.
Old Jun 8, 2011 | 05:51 AM
  #487
dparrish's Avatar
I got it working! I had modify the gray connector to fit the spoolinup harness. "Modify" means file off the lug that stops it fitting into the gray connector.
Attached pics of my boost curve graph in 3rd gear and my WGDC table. Can anyone recommend any improvements? I'm in a stock Evo 8 MR.
Attached Thumbnails HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid-boost-curve.png   HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid-wgdc.png
Old Jun 8, 2011 | 06:01 AM
  #488
05blue8's Avatar
Every car is different. Who is tuning your car? Any "improvements" will rely on alot of factors...mods, timing, fuel, etc. You need to log it, see where everything else is at and go from there. If you're running super rich you can play with it safely a little bit here and there but make sure you at least read up on https://www.evolutionm.net/forums/ec...-tune-evo.html I can say that I'm not new to tuning, I understood a lot but that gave me the confidence to start toying around, it's pretty straight forward. It's the tips and tricks that take a long time to learn
Old Jun 8, 2011 | 06:15 AM
  #489
dparrish's Avatar
I'm tuning my car myself. Or attempting to. I'm new to it but I figure if I make small changes I'll learn. I'm also trying to learn without blowing anything up.
I'm spending so much time logging and looking at the logs I almost see TPS, Load1B and KnockSum in my sleep.
I've read up on the "How to tune an Evo" topic, as well as Merlin's tuning guide. Lots of good info there.
Mostly here I was looking for someone to say "Why the hell does your WGDC map look like that? The 4000 evos I've tuned all have X shape..."
Old Aug 19, 2011 | 03:34 AM
  #490
kiwiracer's Avatar
how do i stop this my turbo ramps so hard its hard to prevent this spike
Attached Thumbnails HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid-spikey.png
Old Aug 19, 2011 | 07:48 PM
  #491
Benja's Avatar
Vertically interpolate (smooth) a load point or two before peak pressure RPM in the WGDC table, that will help reduce the spike.
Old Oct 4, 2011 | 11:10 PM
  #492
prowakeskater's Avatar
for everyones information, the solenoid and pigtail sell on ebay as a package for $45 shipped
Old Oct 5, 2011 | 05:04 PM
  #493
hearnoevo's Avatar
3 port
link?
Old Oct 5, 2011 | 05:19 PM
  #494
http://cgi.ebay.com/ebaymotors/?cmd=...T#ht_763wt_941
Old Oct 20, 2011 | 11:59 AM
  #495
Wait, my pigtail isn't labeled, so how do I connect the wires?
