GM 3.5 BAR MAP Sensor -vs- JDM Map sensor
like $98. Where I work at a shop I knew that if I had a problem with it againg I could get it warrantied.
ps- it is only the factory replacement, not a 3 bar
In any case the main reason to switch to the JDM map sensor is that it allows you to accurately log boost. Mrfred also has another trick where you can directly control boost using it as well.
See
https://www.evolutionm.net/forums/sh...d.php?t=259595
and
https://www.evolutionm.net/forums/sh...d.php?t=293981
