Let's see your fully tuned timing maps
Old Dec 16, 2007 | 07:09 PM
  #241
C6C6CH3vo's Avatar
Originally Posted by mplspilot
That 15.7 - who cares if it's there, it's impossible to use that cell.
Then why change them? Every unused area of the fuel map was randomly adjusted, compare it to a stock one. Trademark perhaps?
Old Dec 16, 2007 | 08:36 PM
  #242
mplspilot's Avatar
I wonder if that's actually it!
Old Dec 17, 2007 | 06:57 AM
  #243
bigric09's Avatar
im sure that is it....
i trademark all the tunes i do with a few different things. Most of the major tuners do that as well.
TTP uses a 69 in the lower corner
Topspeed makes the top line a colorful blend separated by a bunch of 14.7's before the lead in to boost.
Al uses 8's and 9's all over the place except he puts them in the map areas where tuning is important
Old Dec 17, 2007 | 07:33 AM
  #244
Mellon Racing's Avatar
I bet nobody knows what I do
Old Dec 17, 2007 | 07:48 AM
  #245
BCOZEVO's Avatar
Great let me try to find my Mellon decoder ring.
Gezz....
Old Dec 17, 2007 | 07:56 AM
  #246
Owens Racing's Avatar
Sprinkle pixie dust on the tune prior to sending it back. Magical Tunes!
Old Dec 21, 2007 | 05:30 AM
  #247
tkklemann's Avatar
I am almost wondering if he did that on purpose, setting the timing usually more than what the car could handle so that the ECU will pull timing to get it at the correct level.
Its almost like he used the knock control to his advantage, set the timing higher than what the car could handle, use the knock control to let the ECU put the timing where it wanted/needed to be. If the timing was set to low, the ECU wouldn't up it to where it needed to be, and decrease performance.
With a timing map set to low, you would lose performance. With a timing map set to high, you would still gain performance, but the ECU is correcting it to "make it work", but it would still be faster than a timing map set to low.
Flawed logic? There is still no excuse for a fuel map like that. Highway robbery at it's best, literally and figuratively.
Old Dec 21, 2007 | 06:49 AM
  #248
bigric09's Avatar
it makes sense, but using knock to retard timing is just that... retarded
spend the time and do your job title... Tune.
thats why i call myself an adjuster i tune a lot of people, but in the end, i call myself an adjuster
Old Dec 21, 2007 | 07:17 AM
  #249
Mr. Evo IX's Avatar
It was an _ _ tune lol!
That's what I was thinking. Trademark!
Old Dec 21, 2007 | 07:24 AM
  #250
Mr. Evo IX's Avatar
I believe that is precisely the technique he used at the time. Start the knock early and let the ECU sort it out.
Old Dec 21, 2007 | 07:55 AM
  #251
I don't feel good about forcing a car to eat knock and push through it. I prefer to shave off the excess timing so the ECU doesn't get involved in knock control so the car is much more consistent run to run.
Old Dec 21, 2007 | 08:10 AM
  #252
bigric09's Avatar
i dont think anyone does lol
Old Dec 21, 2007 | 08:36 AM
  #253
20psiMR's Avatar
Thank you captain obvious! lol
Old Dec 21, 2007 | 08:43 AM
  #254
BCOZEVO's Avatar
Originally Posted by honki24
I do have lean spool disabled. I have the APS dual vent BOV and leaning out when I snap off throttle helps recovery speed (when not using NLTS)
(easy answer: yeah basically it's to compensate for the VTA aspect of the APS BOV) <APS diverts and vents>
Doesnt the Tial vent in the same way? My lift off and tip in is a bit off right now, so is this method the best way to compsante for that?
Old Dec 21, 2007 | 09:13 AM
  #255
yeah I had quite a bit more in the post but took it out...sometimes I have to think twice about sharing techniques because there are some jerks on the forum that will twist your words into saying something completely different, next thing you know there's 5 other people hitting the punching bag with them. it's just not worth it sometimes.
