Let's see your fully tuned timing maps
Old Jan 11, 2011 | 11:40 AM
  #781
motocooney's Avatar
Here's mine. 93 Octane - 23psi peak / ~20-21psi @ redline.
A/F 11.5 down to ~11.1
Peak load is ~280 or a bit more. 235ish by 7200rpms
Occasional 1-2 counts but very rare and random.
Evo VIII turbo w/ 10.5 hotside. 280 cams / 850cc injectors / MBC / o2 housing / Turboback / header / intake
check it out
Old Feb 2, 2011 | 11:07 AM
  #782
Sirnixalot's Avatar
This is for my Evo 3 with the Evo 8 ecu conversion.
Blitz Intake with Evo 8 MAF, Megan O2, 3" Megan down pipe, 3" Kakimoto exhaust, FIC 750's and BR8ES plugs running 25psi. This made 333whp and 289wtq on virtual dyno (spreadsheet version)
Old Feb 2, 2011 | 12:44 PM
  #783
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
excellent thread!!!!
Old Feb 19, 2011 | 05:08 PM
  #784
escodotcarter's Avatar
check out my map......i bought the car with this tune on it. I have no idea who tuned it. just got my hand on a tactrix cable today and will do some logging tomorrow hopefully. Just FYI i am a complete beginner but even i think this looks a little funky.
Mods are stock 9 turbo, full TBE, Intake, walbro 255, UICP, act hd, hallman mbc, spiking 25 psi tapering to about 21 ish (boost gauge)
i attached the fuel map also.
Attached Thumbnails Let's see your fully tuned timing maps-timingmap.jpg   Let's see your fully tuned timing maps-fuelmap.jpg
Old Feb 19, 2011 | 05:19 PM
  #785
wizzo 8's Avatar
You should probably shift some of those unwanted columns from the left cruise area to the boosted area.
Old Feb 20, 2011 | 07:10 AM
  #786
211Ratsbud's Avatar
Hey guys, what kind of load would be typical of a evo ix with tbe and hks 272s at 3000 rpm? I'm trying to dial in spool up but I'm seeing what I think is compressor surge.
Old Feb 20, 2011 | 04:07 PM
  #787
Raptord's Avatar
Timing at 240+ load makes no sense to me... I don't see why it would go down then back up like that. Timing definitely needs work, fuel is hard to say because we'd need a log.
Old Feb 20, 2011 | 08:18 PM
  #788
Kakihara's Avatar
escodotcarter if your evo is like my IX, you simply can't know what AFR you are running by looking at the fuel map, you need a wideband and log you afrs
my car was tuned by someone else and the fuel maps had absolutely nothing to do with reality, something someone told me was "usual" uh ?
so I did what I read in the must-read Merlins EcuFlash EVO 7-8-9 TUNING GUIDE-V1.7a and made a fuel map with 11.5afr for the most part and the result was the red line :
that...was supposed to be 11.5afr from around 3500rpm to 8000 !
it gives you an idea of how un-reliable just looking at a fuel map is or how messed up a tune can be
SORRY for being off-topic so I'll get back to it...
in case you wonder, the ignition maps are reliable, you should see the same advance you have on the map when logging, unless you have more than 3 or + knocksum which will lower the advance
Old Feb 20, 2011 | 09:24 PM
  #789
_DEN_'s Avatar
my Evo7 ign map
Evo7 260/260 tomei cams (-3, 0)
evo9 turbo
apexi intake
full catback
CR 9.0
Old Feb 20, 2011 | 11:10 PM
  #790
nightwalker's Avatar
check it out
Get rid of the 320 and higher load cells and increase the resolution in the 100-240 load range. It will make your car smoother and you should be able to pick up some midrange torque.
Try lowering the high rpm timing and raising the boost to 25 psi. The car will be faster with more boost.
Old Feb 21, 2011 | 05:01 AM
  #791
Raptord's Avatar
So you just set everything in the fuel map to 11.5? That just sounds borderline dangerous. It's fairly common knowledge that the numbers in the fuel map are just that, numbers; they have little correlation with the actual AFR the car will see at that load/rpm, unless you scale your injectors and MAF to get them to reach those same numbers.
Old Feb 21, 2011 | 07:12 AM
  #792
wow thats crazy variance. i have a wideband but i have to buy a serial cable/adapter to log. so thats on my list.
Old Feb 21, 2011 | 09:43 AM
  #793
211Ratsbud's Avatar
raptord, seems like he did that just to see how far it was off, not for "legitimate power tuning"
Old Feb 22, 2011 | 03:29 AM
  #794
Kakihara's Avatar
Yup, the idea was to visualize the offset between the fuel map and reality, I'm a complete newbie so i tried to understand what was going on.
The picture shows my attempts at scaling the MAF.
It may be "fairly common knowledge" that the fuel maps and reality don't match but I didn't know that at the time.Now I not only know but I can show it to people who are beginners like me in the tuning world.
- fp green 73HTA
- GSC S1
- stock 2l engine
- 24->21psi
- seeing 270->220 load in 4th gear road dyno runs
- 12.214s@112.6mph 1/4mile (no doubt the car can do better)
"not made by me" ignition map, it's not fully tuned since my afrs are still all wrong.
Old Mar 3, 2011 | 03:31 PM
  #795
neonglh's Avatar
I just took a few maps from this thread, and made this one for my 93 octane, stock turbo, exhaust/intake '04 RS. I ended the top at 310, so that I could get more resolution between 100 and 180, and then I averaged the numbers between. See any problems?
Also, what do you guys do for your low-octane map, do you leave it stock, or do you change that as well?
--mark
