MWDC / BDEL question.
Old Dec 11, 2007 | 08:08 PM
EVO8emUp's Avatar
05 Non-MIVEC
What's the difference between...
Max Wastegate Duty Cycle 1
Max Wastegate Duty Cylce 2
Max WastEgate Duty Cycle 3
and
Boost Desired Engine Load 1
Boost Desired Engine Load 2
Boost Desired engine Load 3
When I change these for controlling boost with the factory solenoid, do I have to change all 3, or can I just change #1 of MWDC and # 1 of BDEL?
Old Dec 12, 2007 | 05:03 PM
mrfred's Avatar
Table #1 is the main table. Table #2 is not used by the ECU. Table #3 is used when the car exceeds the "Boost Limiting Vehicle Speed".
Old Dec 12, 2007 | 08:26 PM
codgi's Avatar
This came out of your new delving? Or did i miss when you found this out before?
Old Dec 12, 2007 | 08:54 PM
mrfred's Avatar
From my previous work. I'm sure about #1 and #3, but not entirely sure about #2. I see no calls to it in the code.
Old Dec 12, 2007 | 09:31 PM
RazorLab's Avatar
#1 and #3 BDEL are exactly the same in stock roms however.
Old Dec 12, 2007 | 10:05 PM
mrfred's Avatar
Make #3 different, set the Boost Limiting Speed to something small, and see what happens. :-) I think there are a number of features in the ROM that are not fully utilized.
Old Dec 13, 2007 | 01:30 PM
Mr. Evo IX's Avatar
Mrfred, if #3 is used when the BLVS is exceeded couldn't this be used to reduce boost in taller gears if needed? Or what else happens when BLVS is exceeded?
Old Dec 13, 2007 | 02:19 PM
mrfred's Avatar
It could be used that way. Crossing over the BLVS also affects the WGDC update interval. It could affect other things that I have not researched yet.
Old Dec 13, 2007 | 08:37 PM
codgi's Avatar
How does it affect that interval? Increase/decrease or is that something else you have to poke at ?
Old Dec 13, 2007 | 08:50 PM
mrfred's Avatar
Its user-settable. I can't remember if I posted it, but there are two settings for the interval, one for normal, and one for above BLVS. I think my two boost control mods list instructions to show both settings.
