Inconsistent pulls
Old May 22, 2008 | 05:51 PM
RedLanEVO's Avatar
Inconsistent pulls
I've been trying to tune on e85 lately and have been running into problems. At first my plugs were gapped too big, misfires. Lowered them, misfires but then fixed that up by putting in stock heat range plugs gapped at .024". They work just fine now.
But...I am getting inconsistent logs of my WOT 3rd gear pulls. One pull would have no knock at all, another with a few, then one with bunch of knocks and then another with no knocks. It randomly repeats itself. Here are some of my logs in excel logged with Mitsulogger. These are back to back runs (4 total).
I've been lowering AFRs and timing over and over...not much difference.
Am I running too lean on e85? The AFRs are not consistent too. Timing is pretty consistent until I get knock. I am asking for some help...so please help?
http://www.megafileupload.com/en/fil...74704-zip.html
Old May 22, 2008 | 06:27 PM
RedLanEVO's Avatar
Anyone? Help? Advice? Suggestions?
Old May 22, 2008 | 07:24 PM
RedLanEVO's Avatar
Help? Need this figured out. I'm doing the best I can. This will be a reference for future E85 tuners.
Old May 22, 2008 | 07:33 PM
Ph3n1x's Avatar
Timing and fuel is just toooooo jumpy and inconsistent.
Spool up needs ( looks lean ) to be looked at cause your knocking there which is causing an onset throughout the band.
Wicked E's Avatar
would be nice to know what injectors you're trying to scale with that...
-E
Old May 22, 2008 | 07:36 PM
Ph3n1x's Avatar
That also and how much boost are you running. List mods
Old May 22, 2008 | 07:43 PM
RedLanEVO's Avatar
PTE 1000cc
Old May 22, 2008 | 07:49 PM
Ph3n1x's Avatar
what are the Long term Fuel trims? Relog
Old May 22, 2008 | 09:10 PM
scheides's Avatar
EvoM Moderator
Need wideband AFR's, and are you getting consistent timing numbers pull to pull? What are your IDC's at, are you out of fuel perhaps?
Old May 23, 2008 | 11:27 AM
RedLanEVO's Avatar
Figured it out. It was the AFR's. The fuel map is inconsistent and jumps all over the place like Phenix said. I changed the spool up AFRs and I have consistent pulls now.
Old May 23, 2008 | 07:05 PM
RedLanEVO's Avatar
Now I fixed the spool up to be richer but under WOT pulls starting from 1st, it misses...
Injectors are scaled to 609 now. I guess my map is too rich but I don't know how rich. My AEM Uego doesn't read below 10:1. What AFRs are usually run with E85?
This crap takes up so much fuel...haha
I'm on my 2nd tank of tuning because I'm a noob at this.
Old May 23, 2008 | 07:59 PM
merkzu's Avatar
11.5 on your AEM should be good
Old May 23, 2008 | 08:03 PM
skold's Avatar
on e85 cruising a/fs should be 9.75 on the fuel table and boost should be like 6.5.
Old May 23, 2008 | 08:05 PM
EVO8emUp's Avatar
IIRC, stoich is 9.0:1.
Old May 23, 2008 | 08:24 PM
merkzu's Avatar
You rescale the injector smaller so you can use normal numbers in the table.. You can't even put a number less than 7.4 in there
