TephraMOD V5.10
Old Aug 29, 2008 | 07:35 AM
  #226
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by tephra
if people are interested I can try and solve the immobiliser problem - i Just need to track the code down and get ppl to log stuff for me
Well Tephra I don't know how to log anything but I have made a decision.
Old Aug 31, 2008 | 01:17 PM
  #227
IDRINKV8's Avatar
I tried putting this in and my car didnt start so I had to go back to my other map. Is this common?>
Old Aug 31, 2008 | 01:28 PM
  #228
fixem2's Avatar
Tephra, the immobilizer is no big deal to me. I have had the key/immobilizer thing go out on me in 2 cars and it was a pain! All replaced under warranty but still a hassle.
IDRINKV8, In the map turn off the valet and autovalet Tephra mods or increase the RPM for them. Did you check the immobilizer was moved over correctly?
Old Sep 1, 2008 | 07:19 PM
  #229
IDRINKV8's Avatar
Im not sure Ill check it and see what I can do?
Old Sep 2, 2008 | 11:40 AM
  #230
ace_2822's Avatar
See any thing wronk with that line tephra?
Old Sep 2, 2008 | 02:45 PM
  #231
Youngsyr's Avatar
Just carried out some initial testing on 96260009 on my JDM VIII GSR, map switching seems to work well, I haven't tried the other features yet, but will report back with any problems.
Donation on its way, Tephra!
Old Sep 2, 2008 | 03:56 PM
  #232
tephra's Avatar
nope looks fine to me..
email me the whole xml file..... tephra @ gmail ...
Old Sep 2, 2008 | 05:46 PM
  #233
justboosted02's Avatar
could someone explain the "alternate map load threshold" please?
is this the load that the ecu must be under in order to switch to the altmap?
thanks
Old Sep 2, 2008 | 05:53 PM
  #234
tephra's Avatar
correct.
applies to both ADC0F and AutoICS switching.
However for ADC0F switching it only applies when switching TO altmaps, not FROM... this is so that if your meth runs out mid pull it will switch to normal maps...
Old Sep 3, 2008 | 07:14 PM
  #235
black E's Avatar
^^^^^tephra, you have e-mail......
Old Sep 5, 2008 | 06:11 PM
  #236
Smike's Avatar
05
Trying the 9694011 rear 02 sim fix
(EDIT: Worked great!)
Old Sep 6, 2008 | 01:54 AM
  #237
tephra's Avatar
you can 96530006 over the topof 96940011 - just need to disable the immobiliser
Old Sep 6, 2008 | 05:25 AM
  #238
Smike's Avatar
Interesting. I will give that a shot! Thanks!
Old Sep 6, 2008 | 02:16 PM
  #239
fixem2's Avatar
SmikeEvo, make the switch and you will be very happy with all the fun stuff Tephra has been adding. Been on the 96530006 ROM for awhile now with no issues.
Old Sep 8, 2008 | 04:54 PM
  #240
dudical26's Avatar
tephra - I installed a resistor for the rear 02 sensor this weekend and I am getting the p0037 CEL mentioned earlier in this thread.
All I did was turn on 02 sim, and I also changed the MUT mrfred mentioned for logging via a wideband through the ECU.
The resistor is 75ohm 10watt that J_of_T mentioned in the remove your 02 sensor thread.
Any ideas?
