Fuel cut problem. Logged at 320 load at 25 psi
is it spiking to 320 ? can you put up a graph of the load vs rpm vs boost?
perhaps your piping is too big and the turbo is really pushing more than 25psi, but by the time it gets measured (in the IM) its 25psi...
Takes awhile for the pressure to drop after I kill the compressor. I did the leak test both cold and hot. I know this couplers soften up when its hot. I also retorqued all my clamps.
Things i found to affect load calculations are....
MAF scaling. Hz spikes will screw up the load calc (easily seen at idle)
Boost controller not holding steady. It will allow spikes and screw your load calcualtions
Log with 1 byte or 2byte load = more accurate
Fuel cut, turn the timer way up = no more fuel cut ever
