FP Red is FUN
Some people don't i just wanted to try out the speed density thing
Mainly as a failsafe for running 30psi and blowing out a pipe means i can drive home and put it back on instead of being forced to pull over and put it back on
Well I finally got around to cranking the boost up on e85
Only problem is I'm starting to go lean above 28psi so we are stopping there afr's end up around 12.5. At 30psi i hit 13+ AFR
that was pretty scary lol! E85 must be a very forgiving fuel I must remind myself to be careful with it.
.Only problem is I'm starting to go lean above 28psi so we are stopping there afr's end up around 12.5. At 30psi i hit 13+ AFR
