Virtual Dyno Room-Dyno Simulator
Old May 31, 2010 | 09:52 AM
  #856
cij911's Avatar
^^ Thanks...that did the trick!
First run (still tuning) 417 whp / 360 ft lbs (on stock cams) - dynojet mode....
Old May 31, 2010 | 03:36 PM
  #857
project_skyline's Avatar
Log RPM and thats it. You'll get plenty of data samples.
Old May 31, 2010 | 04:43 PM
  #858
ziad's Avatar
i have the complete opposite problem. i log too many samples (DMA) and the power/torque figrues via the excel program are 10-20% more than if i did a log via evoscan.
brad does ur program use all rpm samples or only 1 rpm point per 50rpm bracket.
Old May 31, 2010 | 08:43 PM
  #859
stackhouse's Avatar
Originally Posted by bbarnhill
Was going to work on this project this weekend while at this 'lovely' wedding weekend extravaganza that I have to go to. BUT ... I left the code back on my desktop. I could kick my own *** sometimes.
Brad, I thought we broke you from programming, did you get Rogers permission to do this ?
All jokes aside, I am glad you still got the itch for writing code. If you need help with anything (testing, or what-not) let me know, but keep it on the dl.
Old Jun 1, 2010 | 05:56 PM
  #860
Jack_of_Trades's Avatar
You CANT log 'too much' with my setup. Thats why I have it do the 50rpm lookup. Well, you can if you exceed the amount of rows I limited it to I guess (2000 rows). How many rows of code were you running?
Other than not being able to get any friggin' free time to fix the bugs in it, it works.
Having it use every data point is best but I saw marginal differences compared to the 50rpm increments so I went that way to minimize the formulas and such.
Old Jun 1, 2010 | 08:54 PM
  #861
ziad's Avatar
jack i did a log with livemap (about 35+samples per second) with evoscan only logging 3 items or so i was at 20ish samples. anyway the the difference in power for the same tune (Slightly different ambient temp was 25+ hp (temp corrections disabled on both). anyway i am looking at finishing livemap vdr and will see in testing how it compares with logs from evoscan.
on the livemap samples the rpm would remain the same over a few lines (As the sample rate is higher) maybe confusing the calculations... plus your VDR shows an abnormally big jump in power over 5000rpm when logged via dma.
Old Jun 2, 2010 | 12:09 AM
  #862
GotWheelHop's Avatar
I noticed the same thing....I have samples where the time changes, but rpm remains the same. DMA logging with 30+ samples a second. I will log with EvoScan and see if there is a difference when the car is back together.
Old Jun 2, 2010 | 09:05 PM
  #863
03RRVIII's Avatar
when are we gonna have the 2010 X's added on the VDR?
Old Jun 2, 2010 | 09:39 PM
  #864
bbarnhill's Avatar
Update on the standalone program ... I have reworked a lot of it and redone the user interface in the last week. One of the forum members has been helping test it (all 26 versions this week) and its still in beta. I may be getting close to releasing it with the understanding its in beta. Ive got to figure out how to deploy it. If anyone has any webspace to (5 megs or so...) that I can publish a clickonce project to let me know. That way I dont have to host the thing from my personal webserver at my house. Otherwise I wont be adding automatic updating into the program to let you know of a new version. If I deploy it with clickonce when I publish an update you will get it next time you start the program.
Let me know what you guys think.
Its still got some bugs and still not finished (some icons missing, some other graphical stuff needs fine tuning) but the majority of it works.
Old Jun 3, 2010 | 03:19 AM
  #865
Mellon Racing's Avatar
Hey Brad, I sent an email with feedback from the latest version, hope that helps
Old Jun 3, 2010 | 06:26 AM
  #866
I'll gladly host it for you on my website man. Cant wait to see the revised version! Just shoot me a PM and I'll host it whenever you want.
Old Jun 3, 2010 | 06:27 AM
  #867
Is there any drivetrain difference between the '08's and the 2010's? If no, just select an '08 X.
Old Jun 3, 2010 | 06:37 AM
  #868
newcomer81's Avatar
I offerd him as well. hosting should be easy to find with most of them switching to unlimited data/storage plans.
no there isn't so the 08 will work exactly the same.
Old Jun 3, 2010 | 05:01 PM
  #869
ziad's Avatar
i think the issue would be regarding .net support and a mswindows server with the clickonce stuff... i have 10gb but only use about 100mb of it but its a linux server
Old Jun 5, 2010 | 07:12 AM
  #870
bbarnhill's Avatar
Im thinking the final version will not be distributed with click once ... I just forsee problems with me trying to distribute it that way.
Stackhouse ... nah you cant take the programmer out of me ... not even satan (Roger). Ill keep it on the DL if you test it. Lord knows what they do to people that have anything to do with programming outside of work. Also if you want to test it let me know and Ill send you a link to where to get it. Its getting real close to the first open beta release of it.
Mellon, your review helped a lot. Thanks for the words of encouragement.
Jack, Ziad, Newcomer ... Ill keep yall in mind as far as hosting goes. It shouldnt be that big of a deal to host it. I dont forsee a TON of traffic.
Ohh and everyone keep in mind that right now I only have Manual Evo X, IX, VIII in there to select from. I WILL be adding more as time goes but right now Im more worried that the thing works correctly. Plus I need the specs (gear ratios, weight, and such) for the other models. Thank you all for the continued support, and Ill get it out to everyone very soon.
Brad
