What A/F ratio should i aim for?
Old Jun 24, 2009 | 10:08 AM
Fairclough's Avatar
I'm tuned at 11.5afr just wondering if i'm leaving alot on the table?
MODS:
GT3037S turbo
Cosworth M2 cams
B/C valvetrain
ARP head studs
AEM Tru boost 30psi
880cc injectors
255lph walbro
custom air/water intercooler
Snow Performance stage 2 meth kit w/safe injection failsafe, boost by-pass solenoid
3" turbo back no cat
custom 3" intake, builing a 4" intake
ACT 6 puck
ACT streetlite flywheel
Thanks in advance.
Old Jun 24, 2009 | 10:19 AM
Fast_Freddie's Avatar
Veteran: Navy
Gas octane...
Old Jun 24, 2009 | 01:17 PM
Fairclough's Avatar
Originally Posted by Fast_Freddie
Gas octane...
Sorry! 91oct and 50/50 meth/water.
Old Jun 24, 2009 | 02:13 PM
Veteran: Navy
This should help you a bit...
Originally Posted by JohnBradley
You can set up a few standalones to enrich or lean based on EGT (or timing for that matter) but it requires individual EGT probes to be done properly. Realistically the time you'd spend is only going to find limited results.
91- 11.0 to 11.3 seems to be the best depending on the turbo (larger will run leaner)
92- 11.5-12.0
93- Havent done one in a while but I am assuming the same basic range as 92
E85- 12.0 on a gas wideband. You can make more on a lean tune but if its run at that level for an extended period of time it will raise combustion chamber temps high enough to lead to piston damage.
Hope that helps a little, some of it is versus RPM as well. Changes to enhance VE will affect how tolerant or intolerant a motor is as well.
aaron
Read here... https://www.evolutionm.net/forums/ec...er-safety.html
Old Jun 24, 2009 | 02:34 PM
Fairclough's Avatar
Thanks!
I know with the air/water intercooler and meth my ONR number is lower, because of the cooler and denser intake charge, I just want a safe, good tune without leaving to much on the table. Thanks again for the info.
CarbonKrazyEvo9
For Sale - Cars For Sale
Jun 19, 2015 10:10 PM
Acree
Jan 16, 2013 12:47 PM
umopp
Nov 19, 2012 04:46 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
black_evo4
16
Jan 28, 2011 05:28 AM
