HELP:Can't view all my parameters for my rom (newbie).
Old Aug 13, 2009 | 02:45 PM
lillev23's Avatar
Well I went to get my car tuned this past Friday. Saturday I tried to view my rom at the track so I could make adjustments to my rev limits but my tactrix cable wouldn't let me into the ecu to view it. I got in touch with my tuner and he said it was because I had to switch my roms to allow map switching (he said I needed 96530706). He sent me the xml for it, but after adding it in my xml file, I could only partially view my rom. I still could not view the any of the Misc. section (stationary rev limit, rev limit, etc.). I checked my rom info and it said that I have 96530202. My rom also has tephramod-v7t6. If anyone can help me I will send them the xml to view it. Any help is truly appreciated. Thanks in advance.
William
Old Aug 13, 2009 | 03:07 PM
dolphin888's Avatar
What is your User Level? If your tuner gave you an xml file, you need to put it in Program Files -> Open ECU -> Ecuflash -> rommedata -> Mitsubishi -> Evo.
Attached Thumbnails HELP:Can't view all my parameters for my rom (newbie).-userlevel.jpg
Old Aug 13, 2009 | 03:19 PM
lillev23's Avatar
I followed that exact same order. Where would I check my user level at?
EDIT: Nevermind. I see the pic you posted. Let me try this out and I'll let you know if that helps any
Old Aug 13, 2009 | 03:22 PM
dolphin888's Avatar
Ecuflash -> File -> Options
Set it to "Developer" level.
Old Aug 13, 2009 | 03:24 PM
lillev23's Avatar
I was already set at the developer level.
Old Aug 13, 2009 | 03:39 PM
dolphin888's Avatar
Then it can be something wrong with your xml file, I would try a "clean", untouched xml file...
Old Aug 13, 2009 | 04:03 PM
lillev23's Avatar
Where would I get this "clean" untouched xml file. Also, would this change anything in my tune?
Old Aug 13, 2009 | 04:24 PM
dolphin888's Avatar
No, it would not change anything, unless you would make some changes in ROM file (not xml).
Maybe someone will share xml file you need, because I don't have it
Old Aug 13, 2009 | 04:35 PM
lillev23's Avatar
Is there something in the xml that I already have that I could change to be able to view my the rest of my rom?
TariqEvo
Dec 9, 2021 12:36 AM
devinfritz
Feb 6, 2015 06:45 PM
211Ratsbud
Mar 23, 2014 02:03 AM
Mitsi7
Aug 10, 2012 01:23 PM
blackvr
20
Apr 10, 2009 01:45 AM
