96530706-V7, possible problem found.
Thanks mrfred,
The new ROM 96530706 with Tephra V7 in it. Under Periphery>EUC periphery0(FAA)bits>
"for immobilizer function disable set to 0"
This particular car that had the problem, the Immobilizer is set correctly, the car is a 2004 EVO RS, we set the Immobilizer hex to 0058 and it still would not start.
It appears that according to the FAA bit for the immobilizer that 0 means the immobilizer is disabled. The car would not start when it was set to 0. When it was set to 1 it would start.
I'd think that if the immobilizer was correct that the car should start with it set to either 0 or 1.
0 being disabled from what I can see should have started the car and did not.
PMing you...
Thanks mrfred,
Thanks mrfred,
To enable the immob. set the periphery bit to 1 and set the immob.
Thanks mrfred,
I tried the 0x0040 for the evo 8 JDM 2003 and my car will not start.
Do you know the value for the hex for 2003 evo 8 JDm, I have tried 0x004B and this does not work either.
Thanks
Dale
Add the XML to your old ROM XML def. to find out what your old Immob. Hex was and use that. I have no idea what the JDM 8 hex would be.....
Verify you have everything copied over including your current immob. key and immob. hex.
If it's still not working put 0x0000 in your immob. key and immob. hex and set periphery bit FAA bit.03 to 0 to disable the immob. setup completely just to check.
Report back....
Report back....
BTW, awesome work all of you!
I know it's a year old thread but just wanted to say thanks as i was hunting all over for that disable immobilizer option and couldnt find it. I have 96530706 running great now in my Evo 3, i converted from 90550001 V5.10
DormantBeast
13
Jul 9, 2017 07:38 AM
