Non-working Evoscan AYC/ACD/ABS datalogging
though, AYC or ACD logging is not working at all with my car (EDM EvoIX, recently purchased OP2.0 from Limitless, ECUFlash 1.42, newest beta EvoScan 2.7.0046)
AYC/ACD bleeding with EvoScan version 2.8!?
Hi there, well I have one customer car which is EVO 8 05' year modle
I'm trying to bleed the air for the AYC and ACD
I've ordered the cable with that feature
I've choose the ACD in the select ECU type
I've choose cable 1.3U
For the DTC I choose MTUIII AYC
I can datalog it says it's engadge even when I press on activation of anything it takes few sec and it works but I don't hear the pump for the AYC or ACD
I've disabled the pin 9 in the OBD II cable and even the feature in the logging for disable flashing light with AYC/ACD
I even rise the volatage up to 13.1 with battery jumper
What is the reason I can't hear the pump ticking, should I make it while the car is on or off I don't think it does matter unless the voltage is low
So what wrong I'm doing missing
I run a screen shot of what I've done from home pc
Thanks for your help and support i really appreciates it!?
Oh sorry where can i get stock EVO 8 map?
I want to use stock GCC map to start from scratch
Thanks!
Thanks!
actuators don't work as well.
my bet is that mr-beast owns a general export car, which is essentially european car, hence it won't work.
it looks like this: evoscan says that it succesfully connects to ACD ecu, then it doesn't do anything at all, can't log any acd data, no actuator is working.
doesn't work on EUDM cars at all, tried every cable in my and my friends' posession.
Interesting topic !
my acd/ayc pump failed on my EUDM IX 6-speed and when we tried to see the error code with an open port 1.3 and a 2.0 we got all ACD failure codes possible
problem that I already had before the pump failure
so there is something to do after all to fix that thx for the info !
what was the rom id of the main ECU on your car (just for the record, since i tried it on 8858 and 8884 to no avail)? is your car LHD or RHD? what exact modifications have you done to the cable, i take it that you have an openport 1.3u?
please let us know the details.
tephra 5.10 96530006
im using a 1.3u tactrix cable
i didnt mod the cable i removed the pins on the cars obd port & swapped them arround i also disconted pin 9 on the car side.
the mods that where required to get evoscan 2.7 to work with the ayc system:
How to get Mitsubishi AYC/ABS support from an OpenPort 1.3U cable.
Step 1) Pin1 must be linked to pin15.
Early OpenPort cables did not have Pin15 linked to pin1(check with a multimeter continuity test) to see if its connected.
a) No pin1 on the OpenPort cable. Move pin1 on the vehicle side to the pin15 position.
b) Pin1 is connected to Pin4/5 on the OpenPort cable. Move pin1 on the vehicle side to the pin15 position.
c) Pin1 is connected to Pin15 on the OpenPort cable. Cable is AYC/ABS ready.
Step 2) Try logging with EvoScan v2.5 or later. Select Mitsubishi, and select ECU to "AYC" or "ABS", Press start datalogger. If it doesn't connect, then perhaps you have pin9 interference. Goto Step 3.
Step 3) Subaru 2002 vehicles use Pin 9 for reflash support, but it interferes with the AYC/ABS ecus on some Mitsubishi obdII ports, so you can either break pin9 off the OpenPort Cable, or put a switch on pin9 on the vehicle OBDII connector.
By the way I have the latest new technology cable plus the latest scanner which is 2.8x!?
Thanks
I don't have to do all of those mods right since my cable is already have the function for the AYC ACD I only have to disable the pin 9 and thats it, and I even tried with pin 9 and without and I can't active the pump at all, it shows that I activated the pump but I don't hear it!?
Thanks
Thanks
My car is an EDM evo 8 with ayc & acd (rhd)
evo4mad
May 5, 2015 06:22 PM
Ceddy
Apr 20, 2011 10:11 AM
fostytou
Mar 16, 2009 08:33 PM
